I have a 2007 Yamaha v-star 650 that has no spark to either coil. Both coils ohm out good. I'm thinking it might the ignition module, but before I shell out that kind of money, because they're not cheap, is there anything else that it could be? Thank you.
The pick up coil. (Also called a pulsar coil). I've found a few bad ones on V-Star 650's thru the years. You can check it with a meter for resistance, insulation breakdown and voltage output. It's located on the lower left side of the engine inline with the crankshaft / flywheel.
Unfortunately Yamaha only sells the pick up coil and stator together with the wires for both bundled together in the rubber grommet.
