2007 Kawasaki Eliminator 125
7082 Views 11 Replies 3 Participants Last post by  Caesium
Hi, I recently bought my first bike from an auction and a main issue i have is that it wont turn on for long.
I try to turn it on for first time in the day and only stays on for a few seconds, i can keep it on for longer if i give it gas but after it dies it wont turn back on.
I can hear some clanking sounds in the engine so im afraid something came loose
That video is of the bike making the sound, any suggestions of what it could be will be helpful.
1 - 12 of 12 Posts
I didn't here it start at all in that video. Just the starter turning over. Is there gas in it?
It could be a ton of things, ignition related( plugs, wires, coils), fuel related (dirty, flooded carbs, fuel lines) etc.
I would start with a good charged battery . Then , check your plugs, ,make sure they are good and you are getting spark. If that checks, it might be a fuel issue. Make sure gas is fresh and check your carburetor
There is a little gas in it, I havent put any new gas but Im about to drain it out and put some new gas in to test it
Im afraid it might be carburetor, I dont really know how to inspect it but if someone had pictures of everything thats plugged into it I could check if its missing anything or somethings wrong
Did u check for spark first. It only takes a second. I would do that before tearing apart the carb
http://www.partzilla.com/parts/sear...liminator+125/CARBURETOR+(A6F-A7F)/parts.html
Kawasaki Motorcycle Parts 2007 BN125A7F Eliminator 125 CARBURETOR (A6F-A7F) Diagram[/url]
Ty for the link and I checked the sparkplug by taking it off and see if it was dirty or something and also used a screw driver to put it in the plug so it sparks. Im currently trying to take out all the gasoline but when i move it I can hear gas sloshing around, do i have to take out 100% of it? b/c its very little whats left and hard to take it out since its on other side of tank which has a bump it has to get over to valve.
I would replace the plug. Idk if your bikes tank is the vacuum or gravity type to get any remaining fuel out. You have a few options. You can use one of those cheap harbor freight transfer pumps. If it's vacuum you have to get suction on the petcock where the hose connects with a mighty vac or get some suction on it and pinch it off. If it's gravity just set to on and it will flow freely once you remove fuel line. Or you can take tank off and shake it out (I've done that). Or u can just leave it. Idk what your plug looks like but I would try a new plug before messing with the carb. It's cheap and easy. Have you tried putting on reserve and starting it?
Yes i did, I set it on the 3 Options: On, Reserve, and Primary. and still it wouldnt go. Ill change the spark plug just to be safe. My tank is a gravity type and emptied out the thing, I put some new gas and started it, two things happened, the battery died since i hadnt turned it on and the gasoline went from the carburetor into the air filter. Im not sure if thats supposed to happen.
You sure it's gas. Oil (small amount) is normal. If it's gas, you might have a stuck float or it could be the float needle. It will have to come apart to inspect. You might want to check your oil too and make sure gas isn't getting in there
In case anyone is wondering or troubleshooting, cleaning the carburetor turned out to be the cause of the fuel leak and not wanting to start. The float was ok but the needle was stuck and very hard to move, i got some carburetor liquid cleaner and WD-40 fixed it. It took a while for it to turn on but after letting it run on its own it didnt spill anything.
I rode it for a few minutes and its awesome, but whenever I stop the engine dies. If i get to a stop i have to put it in neutral and give it gas for it to keep running, I dont know what is causing this though.
1 - 12 of 12 Posts
