1 - 20 of 21 Posts
bsa_bob
This bonne has A 19" wheel on the front, with A 90 something tire .quite narrow. I adjusted the air pressure in it to 22lbs, but am getting verbal ubuse, on it being unsafe. At this pressure.What can you share with me, to get this harder ride out of it. The front suspension works As it should. just the that the seams in the asphalt ..are the reason for this post.
bob s
I think it's best to go with what air pressure the bike recommends, but heck, I'm new to riding, so other's may have better suggestions. I hate the seams/cracks in the pavement and try to avoid them. If I have to cross over one, I try to do it at an angle if possible. To me it seems like the bike wants to go where the seam/crack goes, I don't like to let the bike decide, I like being in control.
Low air pressure will shorten the life of the tire and take away traction that you need to be safe in corners.
bsa_bob
thank you Zippy I ride about like "pee wee herman" did his bicycle in pee wees to bile/ far As wear out if i can make this america ride aliitle better i am open to suggestions//
Riding with the air pressure too low in the tires can be dangerous because of the risk of tire failure. You don't want a blowout on two wheels.
bsa_bob
well we have answered eveything cept but what i needed to know! but thanks dodsfall bob s
bsa_bob
Discussion Starter #7 (Edited)
Replacing the suspension with higher quality fork springs and shocks can provide a softer ride.
Whose frnt progressive springs would you install?jus askin / need a brand name.Some in pictures /brands they look like they are wound further and tighter --in one end than they are in the other?
thank you Dodsfall appreciated greatly bob s:coffee:
Troublemaker
Changing the suspension will also change the handling. Running the tire low on pressure will cause the tire to cup, wear unevenly, and cause unsafe handling, sidewall flex will be greatly increased and allow the tire to contact the road incorrectly.
I have a 90/90-21 on the front of my bike, it handles the cracks and seams in the road much better when properly inflated, that makes riding more comfortable. I go by the tire as far as inflation, that is what the tire manufacturer tests them at for safety and reliability. The numbers on the bike are just an average that gives the best ride, and that leads to longer component lifespan.
bsa_bob
Discussion Starter #10
only reason for lowering pressure, was because this B/A has a large tire on the back and this big 19" skinny tire on the front . maybe it would be better to find the stock front rim- and get a Bette ride altogether ...whats your take on doing this? bob s
bsa_bob
Discussion Starter #11
axel in front had play in it .not enough washer shims so i tighened it up now hits lots softer thanks all for the help bob s
bsa_bob
Discussion Starter #12
thank you Zippy I ride about like "pee wee herman./ far As wear out -if i can make this america ride a little better i am open to suggestions//
hope i can get this going......yes i did i had the wheel loose between the fork tubes , one more washer took care of it ,tire prssue back to normal thanks all bob s
What about switching to a car tire? Nothing like someone putting a car tire on a motorcycle to get the comments flying!
Female Rider
I don't think ANYONE could flat foot it either. LOL
But it would make a statement riding down mainstreet USA.
you don't have to flat foot it Moni, just have good balance on those wide tires
1 - 20 of 21 Posts
