I purchased an R6 about 2 weeks ago and am having a problem in my starter relay. One of the fuses keeps blowing. I replaced it with the same one that it had in it. I am also not finding anything in the owners manual about fuse sizes. One is a 30amp and the one I've had to replace is a 10 amp. I am pretty sure that is my problem I think both need 30amp fuses but I am not sure cause I cannot find any info on what sizes they need to be. I've checked the connections from the battery to the relay and their is no indication of it shorting out on the frame anywhere so I think I'm using the wrong size fuse. Can someone confirm this for me? I've also had a problem where the fuel pump wasn't priming when I turned the key? Could that be related to the starter relay?
