1 - 12 of 12 Posts
Hey I was wondering if there was any way to improve the acceleration of the 2003 Honda rebel. I know it's a little 250 but ya know, who doesn't wanna go a bit faster. Also, any advice on how I could put a tachometer on it and extend the foot pegs along with the gear shorter and brake? Thanks! :)
You can probably find an electronic tach that works off the coil and mount that up to your handlebars or somewhere. I don't know if forward controls are offered for that bike, but a call to the JP Cycles metric tech line might help with that.
Are you looking to improve the acceleration or the top speed? (Usually one can be sacrificed in favor of the other by final drive gearing changes)
Thanks! I had seen the clip on the hand bar tachs but I didn't know how accurate they were.
And I am more interested in acceleration, I don't go on the highway so top speed isn't a concern
Troublemaker
I am sure you can change sprockets, but you will definitely give up some top end in order to gain a little acceleration. Top end isn't that great if you weigh more than a few pounds.
If more acceleration is what you are after, it would be a good time to sell the Rebel and get a bike that is built more for what you want out of it.
Rebels are more training and city bikes, that and being reliable are about all they are. They do a good job of holding resale value too.
Engine-wise you could open the intake, add a more open 2-1 exhaust and re-jet the carb for the new configuration. The horsepower gain would be minimal, however.
Why not just trade up? That's half the fun of bikes, getting different ones.:thumbsup:
One simple way to improve a bike's acceleration is to lose some of its weight.. anything you can shed from the bike?
Discussion Starter #9
Well I don't want to lose the fuel efficiency of the rebel, and from what I read on sprocket changes they just increased the top end speed, and it's pretty bare bones and I'm 5'11" 170lbs so not much to lose :/.
Sprocket changes can also do the opposite. A larger rear sprocket will reduce top end speed and effectively lower the gear ratio. Of course you may end up with a 30 MPH top speed, but you can get there quicker. :D
I would recommend one of the specific Honda Rebel forums (there are two). Those guys have a lot of experience with Rebels. Great little bikes, by the way. I ride one.
Sent from my iPad using Tapatalk
1 - 12 of 12 Posts
