the whole reason I bought the bike was to do stunts. But you said something with the shock? Should I just replace the whole shock all together or see if anything came unplugged first?You obviously knocked something loose, or broke something from the shock.
You'll find that most bikes work much better, and last a lot longer, if you keep both wheels on the ground and drive them a little easier.
U could just be helpful instead of being a sarcastic dickI will need terminology I can understand. Crank is when the engine is turning when the starter button is pressed. As in cranking but not running.
Shut off implies the engine was running, as in fired up after cranking. So: Did the engine crank over ? Did it fire and run ?
What system is used to provide fuel to the engine? A fuel injector has a hard time bending a float for instance.
Shock or hard landing, could be what happened when the front wheel returned to earth. As in I was shocked to discover some dipstick stole my bike.
Shock is what the suspension unit is called to control the back wheel up and down. Your engine running problem would not be related to the rear shock, but is probably related to the shock of landing.
The hard landing may have shaken ( close enough to the past tense of shock ) something lose in the wyring department. Or it may have upset a float bowl or two in the carbs if it has them. But you did not tell us that bit, and I am not going to look it up. So Mr wheelie king, you need to be a detective and start checking on things, and give us more info.
My hands are shaking like a leaf on a tree, I'm all shook up " Elvis.
UK
It takes a lot of practice to achieve that level.U could just be helpful instead of being a sarcastic dick
^ First good answer ^You obviously knocked something loose, or broke something from the shock.
See Unkle Krusty's "shock" information below....But you said something with the shock? Should I just replace the whole shock all together or see if anything came unplugged first?
^ Good information for a guy to have ^Shock is what the suspension unit is called to control the back wheel up and down. Your engine running problem would not be related to the rear shock,
^ Or an electronic component, or plug for said component. ... Second (^) and third (<) try ...The hard landing may have shaken ( close enough to the past tense of shock ) something lose in the wyring department.
And I'm out...U could just be helpful instead of being a sarcastic dick
You won't complain when things start not working correctly either will you. You are prepared for the inevitable, right???I can get this bad boy AIRBOURNE. That's 2 wheels in the air, same time.
Yeah, I don't really do wheelies anymore.Wheelies?
