1 - 10 of 10 Posts
· Registered
Help - Bike idles a little rough, runs great when accelerating, but holding speed and rolling onto throttle after deceleration the engine hesitates, once enough throttle is applied it responds and runs great again.
Any Ideas?
Thanks in advance.
· Registered
Discussion Starter · #5 ·
I replaced the plugs over the weekend. They had varnish on them, but it didn't solve the problem. I also noticed that while the bike is running it smells like fuel, running rich I think. I originally thought the carbs may need cleaning, but am not sure if that would cause it to smell. Any ideas?
Thanks
· Registered
Discussion Starter · #8 ·
I pulled the carbs and cleaned them. I have re-installed them, the bike starts, but runs awful (worse than before). Is this because the carbs need to be synched now that I opened them?
Thanks
· Shantytown Mayor
Possibly. Check for vacuum leaks also. To do this spray a little carb cleaner around the intakes while it's runnin' When the engine either smooths out you found the leak.
1 - 10 of 10 Posts
