· Registered
How's everybody doing? Recently acquired a 1996 Honda Magna 750. Was told it sat up for about 10 years, and I'm trying to figure out what all i need to check out/replace.
Here is what I know:
Bike turns on(lights and ignition)
I have emptied the gas tank and found a bit of rust floating around
The reserve tube has a cut in it
Any and all help will be greatly appreciated.
Ride safe guys!
· On The Road Again!
The rust in the tank will be a killer. You have to remove ALL of it or it will make it's way to the
tiny jets in the carburetors. After you've removed all of the loose rust that you can, treat the
inside of the tank with phosphoric acid. That stuff turns iron oxide (rust) into iron phosphate which
is a protective coating.
Good luck with your project!
· Visionary
Along with getting rid of the rust in the tank I think you need to see if the engine turns over, not start, just see if it cranks over.
I'd probably pull the plugs, squirt a bit of oil in each cylinder, then hit the starter and see if it spins.
If it does then you can start going over things like brakes, oil, tires, carburetors, etc.
If it doesn't crank over then you need to find out why and fix it or else your project is dead in the water.
Reactions: Miss Mercedes
· Loves All Motorcycles
First thing I do with a new project is see if I can get it to turn over or fire. So long as it turns over I know I have the basic recipe for motorcycle fun. And if it fires, you're only a couple steps from a runner! The tank will be easy to fix. Shove some rust killing agent in it (muriatic acid or some specific product), let it do its job, then coat the insides with something like POR-15. :)
Reactions: mike721
