This bike has a flat spot with acceleration. Rebuilt carbs. Singed carbs. But still have a hesitation when accelerating. Runs fairly well up to about 3000 rpm but when I accelerate farther engine starts to die, almost completely. However if I open the throttle all the way it catches and takes off like it should. Any ideas why it is doing this?
Do you have stock jets and exhaust?
What elevation are you at?
I would do all the routine maintenance and tune up procedures.
I've heard that mid-range flat spot you describe is common (at least on my modal) at higher elevations. Maybe as low as 5 or 6 thousand feet.
Discussion Starter #6 (Edited)
I forgot to mention that I’m at the Jersey shore. Any lower and my feet will get soaked. I’ve had issues with other bikes, like you
mentioned, at higher elevations wher I had to retune for higher elevations. I have read these bikes have issues with flat spots, they recommended resetting to, I think point 1.40 jets. Haven’t tried this, I guess that is the next experiment. Thanks much for responding. Stay healthy!
