1 - 2 of 2 Posts
I have a 93' Nighthawk. I went to turn it on and I am not getting power to my gauges. The last time I rode it, it was fine. I checked the battery and i am getting a charge. I also checked all the fuses and they are fine. I checked all the connections behind the headlight and they are getting power and connected tight. Anyone know what might be wrong or what to check?
Jack of all Trades, Master of None
Sorry for the delayed response.
Are you sure there aren't any fuses you could have missed? If I am reading your post correctly, you have power to the gauges, but the gauges themselves are not working? Or are you just talking about the illumination lamps for the gauges?
If there's power to the gauges, but they aren't operational, it could be a grounding issue. Trace the wires to find the ground points and make sure they are good and clean.
1 - 2 of 2 Posts
