First time riding my Nighthawk since the fall. There was some stabilizer in the fuel over the winter, and the carbs were replaced last spring so they're pretty new still. I let the bike warm up for a bit, turned off the choke and it idled fine. Whenever I revved the throttle it died, until I put the choke back on.
I had to keep the choke on for over 15 minutes of riding around before I could turn it off and rev the engine without making it die. Any ideas of what it could be?
Did you drain the fuel from your carbs before storage? It could be your stabilizer didn't keep the fuel from leaving a coating in the jets. Try a tank or two of a good fuel system cleaner, and see if it clears up; it couldn't hurt, and it's a lot easier than taking them apart.
I didn't do that. I would've thought they'd be fine since they were just replaced last spring, but I'm new to bikes so I really don't know. Thanks for the info I'll try it!
