I have noticed the left cylnder seems to run cooler than the right. Bike runs well, rough Idle a bit but nothing major. Wondered if anyone had any thoughts on this. Bike is great and has 92K miles on it.
Carb synch should do the trick. Pull one plug wire and check the RPM's, then put it back on, then pull the other plug. That's the quick and easy way to check it first.
Good luck!
I am unable to disconnect either plug while the bike is running . Bike cuts out immediatly. Looks Like I am left with the Vaccum Tubes to balance the carbs.
