Was getting around to replacing an airbox on a 1984 CT110 - basically switching it out for what I thought was a 1:1 part of the airbox. Anyway the filter and the part is virtually identical but doesn't have hoses available for the oil/drain crankcase venting. My understanding of the function of these is limited but are these even necessary? I believe earlier models ran fine without them but I don't want to discount the idea that these were added for a reason. I just didn't want to fire this thing up and do more harm than good. I looked around quite a bit for a similar airbox for later models but most are in worse shape than the one I set out to replace.
Worth noting the other tapatalk CT110 specific forum I was trying to post at died - I know this is a real specific question.
Anybody have experience with this - and if so should I just leave it as it is or potentially use drill out a similar hole in the new one?
http://dratv.com/ck2ainewmore.html - the link for reference to the replacement part in question.
This is a side by side comparison new one to the left - old one to the right:
67258
This is the old one hooked up.
This is inside the old one - its just got a small reservoir at the bottom of the tank - the new one just goes straight through.
67261
Thanks
You didn't figure out much from that thread. Crankcase needs to breathe clean air and be able to expel water and blow-by gasses from the crankcase on every single stroke of the engine. Your bike had a positive crankcase ventilation system before likely because it was intended for import and the parts you source are likely not.
How are you going to deal with the hoses?
A couple of under-sized holes drilled would, get by.
