How good did you clean the carbs? Take them apart and clean them. Run a wire through the jets and if you look on the pilot jet there are tiny holes at the top of it on the sides. If they are plugged up it will not idle. In short I would say it's the carbs. You may want to invest in rebuild kits which you can buy off Ebay, Old Bike Barn or Parts n More. They come with new jets, needle and seat, slide needle and gaskets.
www.oldbikebarn.com
www.partsnmore.com
Other than that the whole fresh gas, clean fliter, yadda yadda you know because ya already done that. Another thing to check for is check the carb boots for cracking due to age. If they leak air it won't run right.
www.oldbikebarn.com
www.partsnmore.com
