I've been riding it regularly. Today it wouldn't start. When I push the electric start the headlight brightens but no sound anywhere. Also, the instrument panel lights turn on as well.
Help appreciated. Newbie here
Ghost in the machine
Start by checking your battery and starter cable connections. Then volt test your battery.
Female Rider
First things I would check is the on/off switch. Then make sure you are in neutral and your kick stand is up and try it again. I've experienced that nothing thing and it was the switch being turned off or the bike was in gear and my kickstand was down. Mine won't start either way. Also, when I bought my bike I got it really cheap because it wouldn't start...turned out the safety switch wire to the kickstand was unplugged. Lucky me!!!
If it's not one of those I'd be checking the starter switch. If the lights brighten I would tend to doubt it's the battery...but it could be. Voltage meter time then. Good Luck to you!
