I just joined the forum because I am looking at purchasing a bike. Its a 1985 K100 (looks to be the 100LT because of the saddle bags). The guy offered it to me for $300. It is not in bad shape as far as appearance but it does not run according to him.
He told me he concentrated on cleaning the fuel system and had a problem with blowing fuses. He tracked it to a coolant sensor and fixed it. If he pushes the start button the fuel pump comes on but starter does not engage. He said he check the regular things you would check when the engine doesn't start but those did not fix the problem. He also threw in a comment that it "needs a new set of eyes on it" and I am assuming he means someone else to look at it but did not know if that was a part I was not recognizing.
What are yalls thoughts on this for $300? What do you think the things to check to try and find a solution are?
Thank you for your time,
Spencer
Spencer
