Especially in the rain.Don't ride too aggressively on new tires until you get the treads roughed up a bit. They can be a bit slippery when new.
Worth stating a third time.
Murky fluid does indicate moisture but you can be sure a lot of that moisture settled in the lowest part of the system, the caliper... Always does, every time.but murky brake fluid is indicative of moisture in the line, right ?
If you didn't get a good seal you will find fluid leaks at any place the seal is not sealed well. No fluid leak, good seal.When I put the brake lines on I did the "build it yourself" with SS braided line and may not have gotten the best seal?
