I have an xj500. the last time i drove it, it flooded the crank with gas to a point it was leaking out the sides of the seals. any ideas?
Does this bike have vacuum petcocks? My 1980 Yamaha did and I had the same problem when they got old and quit working properly. I had to swap out the petcocks (to gravity style) in order to avoid the dreaded gas-oil nightmare.
I'd get it checked out ASAP if I were you. Mixing gas and oil won't do anything good to your engine...
xj 550 carb
Thanks. I have no idea. These issues are over my head! !. I am however going to keep an eye on it and change the oil. Thanks again....
Good plan - smell the oil when you drain it, if you can detect a strong odor of gas then it needs be looked at by a mechanic before too long or it could cause serious engine damage.
