1 - 2 of 2 Posts
· Registered
I’ve been working on this old Honda and have ran into and issue. Everything electronically works (Starter motor, Lights, and everything else) but I’m at not getting spark. I replaced the ignition coil and tested it and everything is fine. Any suggestions of what’s wrong?
· Premium Member
Got a Voltmeter? If so, check that there is power at the points when they are opened by the cam, and the key is on. If not, then follow the wires back to the coil(s), and from there to the run/stop switch.
1 - 2 of 2 Posts
