Hello everyone.
With some good help from this forum we determined that the generator rotor was the final (hopefully) reason the charging system isn't working.
We purchased the special tool from Honda to jack the rotor off the taper on the end of the crank shaft. the special tool is two special bolts
The inner bold has no head and threads into the tapped hole on the end of the shaft. The outer bolt is hollow and threads into the rotor over the inner bolt. The outer bold works against the inner bolt and in theory pulls the rotor off the taper.
We tried hard last night and succeeded in stripping the cast iron threads out of the rotor.
The fact that the stator was brand new when we bought the bike leads me to the sad conclusion that the seller may have known the rotor was frozen on the shaft and decided to sell the bike.
Any suggestions how to get the rotor off? I don't really want to wail on it with a hammer since every impact ends up on a bearing somewhere. We have removed the core wire all that is on the bike now is the inner half of the rotor. It is a massive chunk of cast iron so I don't know if we could heat it up enough with a mapp gas torch or even if heating it up will help.
I'm hoping that there is some way short of pulling the motor and taking the crank shaft out. I suspect you have to pull the rotor off to get the crank shat out of the block anyway.
