I recently bought a 1980 suzuki gs550e that seemed to run and drive great. The day after I bought it it fired up perfectly that morning, played a bit, then let it sit for a few hrs while doing other stuff. After a few hrs I went to ride it again and no start. It would cough but not actually fire. Tried having battery charger on it to make sure battery wasnt problem no change. Filled it with 91oct gas and put seafoam in the tank as the tank was fairly low. No change. I pulled the fuel lines off and found that with the main line disconnected the vaccum line does pull fuel from the tank. The main line however seems to be clogged to blow through it. I blew through the vent line which then freed up the main line. Bike fired right up ran a bit rough at first then smoothed out and rode fine. I have to do this everytime I want to start it. The lever on the petcock is broken off so I cant do anything with it, am pulling a part number from it today to get a new one. Once the bike is god and hot it wants to idle just above 3k rpm which seems like a lot and doesnt seem happy there. Any suggestions? Thank you
