bike has 13k miles nice old bike all orignal. will a bad rotor stator make it run bad and cut out and not revv high . changed voltage regulator carbs are good. will a rotor stator bad not give the electric system enough power to make it fire right.. it has fire on num 3 but not hitting dead miss has good compression. it has spark but I think its weak... like the stator not putting out enough power to completely power the system thoroughly, I went and pulled the engine and topend just to find its perfectly fine looks great besides the center cam chain tensioner spring was broke and fell down in it so its not a complete mistake by taking it apart im going to put it back together just the way it was even the rings in the same spot they was in not honing it can still see the factory hone marks. anybody have anything think I should do to it while I have it apart . checked the valves everythings good on it no cracks or leaks
