My bike was running normal before I changed out the speedo and tach bulbs. Not sure what I did but it is all messed up now. Neutral light is always on even when the key in off position and out. I can crank it over in all 3 ignition positions unless the headlight is plugged in. Turn signals do not work, instead the brake and guage lights flash. Brake in back is on until I press the brake then it turns off. New battery. Like I said everything was working normal and as it should prior
Did you put the same bulbs in it that you took out?
Do you still have the old ones? Put them back in and see what happens.
Yes I tried putting the old burnt out ones back in but there was no change, still acting up
And without any bulbs? Could you have shorted something out?
