1975 Honda CB360 seat replacement
628 Views 3 Replies 3 Participants Last post by  Traveller11
Hello! I recently bought a '75 CB360 and it needs a new seat, not only is the material coming off but the metal that the hinge mounts to has broken as well, is there an aftermarket seat that's known to fit the 360 or will I have to do some fabrication either way? Thanks!
Type "'75 Honda CB360 seat" on ebay and find what you need for yours. :giggle:
  • Helpful
Have the hinge welded and buy a cover for the seat.
I recovered my Intruder seat using a cover I fond on ebay. It worked great and was easy to do.
Remove the old cover and just check the foam to make sure it is still good. You could add a layer of foam at this point if you want to beef up the seat a bit or even shave away some foam if you want to reshape the seat. Put the new cover in the dryer for about 5 minutes, just get it warm not hot. Have a hair dryer on hand just in case you need to re heat. Start at the front of the seat and work your way back. Once the new cover is pretty much in place start stapling it in place using 1/4 inch staples from the front to the rear. Use plenty of staples don't be stingy. Cut away any excess material but leave about 1 inch or more between the edge and the staple line. It is really easy. The key is to make sure it is stretched tight when still warm.
Or there is this. I have no idea how good they are.
