1 - 2 of 2 Posts
Hi,
Can you advise the name of the highlighted part (where the PO kluged up a fix) and where I might find it? It is where the throttle cable splits in to two cables. My second question is about the throttle valve needle (I hope that is the correct name). It is loose and will wiggle side-to-side mayne 1/16 to 1/8 inch. I have an older Datsun with a sort of similar setup and the pin does not move at all and the depth is set precisely.
Thanks for any help/advice,
Thomas
1 - 2 of 2 Posts
