I know, I need to quit putting off the headlight circuitry, but there are plenty of other problems to distract me.
Like the front shocks, for instance. They've been bottoming out with ease. I've searched, but haven't found anything on replacement or rebuilt CT90 K0 leading link shocks, and I haven't found anything on rebuilding the shocks. From what I've read, you can't even rebuild them yourself.
There are, however, C70 shocks readily available. I figured that anything would be better than the ones I have now, so I decided to order a pair. I was right. They fit pretty good, other than the bracket for the arm being a washers width too wide. I guess you know how I fixed that. I removed the old shocks to see that they telescoped about an inch farther than the springs, and had no return at all. The new ones, however, fit snug in every aspect, and were the same length as the old ones. The ride is much better now, I haven't bottomed out on dirt roads or potholes. Now maybe I should get to the headlight since I'm currently on a tight budget.
