This site requests you introduce yourself before asking questions so people know you are serious and not a post and run type poster. Introductions found here ... https://www.motorcycleforum.com/forums/new-member-introduction.305/
hello all I just want to know is it possible to change the 1200 bandit cdi with a 600 bandit cdi
if so what is different between the 2 cdi's
Nightfly
short answer: definitely NO
long answer: B1200 has throttle position sensor from first day of production, B600 has TPS only since facelift in 2001 when Keihin carbs were replaced by Mikunis. TPS signal would be missing by CDI and wiring can be different. Most probably even connectors won't be compatible. Ignition coils would most likely be an additional problem
