I have been using Rotella T (Shell) 15 - 40 for a couple of years. I really like it.
thanks oil doc I am going to synthetics on every thing next change my dealer,Great post Si...
FYI.... you were correct on AMSOIL. it was a Di-Ester based product in the Early Years. All the Amsoil Synthetics, are a PAO Base with Esters.
You will ALWAYS find a few that will say "I ran XYZ oil for 50 years and never had a Problem" Oil has changed just in the last 12 months, much less 5 or 10 years.
Which brings us to the Mobil 1 and clutch slippage.. I sell a lot of MotorCycle Oil... There will always be some that don't have a problem but I have been coming across the problem where people are experiencing clutch slippage or clutch chatter after an oil change... What I have been noticing is that these people have been trying to save a buck and run Mobil 1 Automotive instead of paying the Extra for a Premium Quality MotorCycle Specific Synthetic... After all, it's just marketing and all oils are the same right ? Nothing could be further from the truth... Today, there IS A DIFFERENCE !
Doc
Most people think of oil as a way to reduce wear. And that's true. The only thing it does is reduce wear on friction surfaces. Synthetics are a lot different though. They're almost a wear arrestor. In other words, once you have worked all of the conventional oil out of the system (which might take several oil changes), there's almost ZERO wear from that day forward. Whatever wear you have in your engine now, when you switch, you will have in another 100,000 miles from now. There are some exceptions though. It won't save an otherwise dying engine. If you burned the bearings, spun a rod bearing, or what not, it's not going to help that and the engine will continue on its path towards destruction regardless of the oil used. But if you take a motor with 10,000 miles on it that's always run conventional oil and tear it down, take pictures and note the wear on its internals, and then you switch to synthetics and run it an additional 100,000 miles and tear it apart, you will see almost the EXACT same wear you had at 10,000 miles! These oils are so good, in fact, that they can actually keep a new engine from breaking in! Seriously! It's amazing sh!t!thanks oil doc I am going to synthetics on every thing next change my dealer,
has told me that it is so much better and wont break down like regular oil will
I do know something about oil ,Work in refrigeration and we must use the correct oil or the system will get stopped up because of the oil & refrigerant mix
must be wright or it will course it to fail much sooner thanks for the info I understand about using the stuff for every thing even your lawn mower,
use the wright lub and it will last & last if not you will be buying a norther one ,
sooner than you thought ,Biker Bob
Everything I own, bikes, cars, everything except my boats and lawn equipment run K&N's. Can't beat the mileage and ease of maintenance. I use Amsoil filters too, not sure about the EA bit tho.
I can see how that could happen though, especially through the crank vent or PCV system.
