#1 |
I ride a 2002 cbr600f4i, and shes having some troubles. When I turn the key, all the lights come on, just like usual. When I turn the engine stop switch on, however, you can't hear the fuel injection turning on, and when the starter button is pressed, nothing happens.
Could this be the result of a blown fuse? I was also thinking that maybe the engine stop switch is broken somehow, because all the electrical still works. Any ideas from the MCF masters would be greatly appreciated. |
#2 |
Psychotic Reader
Location: Beautiful Ozarks in the middle of Razorback Country
Kill switch, neutral switch...what else is going on?
Wayne S
AttaBoy x Ten To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#3 |
Main battery cable connection,condition of the battery. other wire connections,safety relays,,and or a fuse.. What else is going on?? Whos repair manual do you have so we can follow on the same page??
#4 |
Motorcyclist
Check the actual electrical connection to the fuel pump. There should be a plug/conector somewhere with some wires in it.
Had the same issue on my K75. |
#5 |
Sounds dumb, but make sure the bikes in neutral.
#6 |
Fixed it, I just checked the connections to the starter relay, cleaned them off a bit, then went to start it to listen for the click and it turned on. Sweet.
I think the connection just became loose or something. |
