Old 11-28-2009, 02:47 PM   #1
artyboy
artyboy is on a distinguished road
Default Fires but dies immediately
I've got an '08 Suzuki GSX650F. I went to start it the other day and it wouldn't stay started. It fires if I give it a lot of gass but it immediately dies. Could it be the battery if it's firing? or is it the fuel injection or fuel pump? The last time I had it out I rode it all day and had no issues. I've never had any other problems with it. It always fires right up immediately. I don't want to pay a shop if there's an easy fix but I'm hardly a mechanic. Any advice woudl be appreciated.
artyboy is offline   Reply With Quote
Old 11-28-2009, 04:46 PM   #2
Biker Dash
Site Brony and Troll Eater
Biker Dash's Avatar
Biker Dash has a spectacular aura about
A clogged fuel filter maybe? od a kink in one of the fuel lines? if you check out those to items, you might find the culprit.
Biker Dash is offline   Reply With Quote
Old 12-12-2009, 06:55 AM   #3
benny hedges
Veryfried
benny hedges's Avatar
benny hedges will become famous soon enough
i had a 125 single years ago that would kick over every time but die as soon as i touched the throttle.
tried everything i could think of and finally found the problem - the woodruff key had sheared on the flywheel and the torque of the engine turning was knocking the ingition timing out.
what a pain lol - all for a tiny sliver of steel that cost pence to replace!
benny hedges is offline   Reply With Quote
Old 12-12-2009, 08:52 AM   #4
Plumcrazy
Psychotic Reader
Plumcrazy's Avatar
Location: Beautiful Ozarks in the middle of Razorback Country
Plumcrazy is on a distinguished road
I would go with the easier of the two options and then consider major problems...don't look for trouble.
So second vote for clogged gas line/filter
Wayne S
AttaBoy x Ten
Plumcrazy is offline   Reply With Quote
Search this Thread:
Advanced Search
