Honda CX500 trouble. - Motorcycle Forum
Thread Tools
Old 11-23-2009, 05:34 PM   #1
FreakyFastFiero
Newbie
FreakyFastFiero is on a distinguished road
Default Honda CX500 trouble.
I just bought a 1979 Honda CX 500 Custom that only was running on one clyinder, most of the time. When it did run on two, which was not very often, it instantly went back to one when I opened up. The guy I got it from thought that the coil was bad but I tested for spark and it was good. So then I thought that it was just a dirty carb, so I cleaned it and put it all back together and still have some problems. It only consistantly runs on one cylinder. I checked and found that it has pretty good compression. I'm now thinking that it might have a sticky valve that only opens some of the time. I think this because sometime the bike shoots flames out the exhaust. I figure that the valve sticks and gets loaded with fuel. When it then opens it floods the engine and causes it to run like junk, if at all. One more thing, when I run it with the choke on the good running side's carb fills up with so much fuel that it overflows, yet the bad side does not over flow. I'm kind of new to bikes, but am pretty handy with cars, so just let me know what you think. (Also could it be a loose cam chain which could have caused a timing issue?)
Thanks.
FreakyFastFiero is offline   Reply With Quote
Old 11-23-2009, 06:48 PM   #2
benny hedges
Veryfried
benny hedges's Avatar
benny hedges will become famous soon enough
look in the free manuals thread - theres a repair manual for the cx and silverwing.
search your earlier posts cos i put some links up to you to a cx / sw owners site and manual
unlikely to be a intermittent valve problem.
first thing. compression test.
get the carbs stripped and cleaned.
is the bad side the side it leans when its on the stand????
check the ignition lt & ht wiring, its not firing cos its not sparking.
it might spark when you turn it but not under compression.
get the manual and post back.
cx is easy to work on.
* earlier post
http://www.motorcycleforum.com/showt...370#post660370
benny hedges is offline   Reply With Quote
Old 11-24-2009, 05:52 PM   #3
FreakyFastFiero
Newbie
I will try to swap out the coils. I have another set and will post back later.
Old 11-24-2009, 10:59 PM   #4
dang84119
dang84119's Avatar
dang84119 is on a distinguished road
Whats up FreakyFast I just got through rebuilding a 1979 cx500c motor from the crankshaft up about a month ago. It took me a lot of time and effort and I could not have done it without this resource http://choppercharles.com/cs/
There you will find a service manual for this bike as well as a lot of money saving ideas.
This bike as you will learn has a HUGE following and tons of support through this site.
Here is a link for a FREE complete service manual for the cx500c that you have
http://drop.io/CX500_GL500?page=4
dang84119 is offline   Reply With Quote
Old 12-01-2011, 06:48 AM   #5
dudds1960
dudds1960 is on a distinguished road
Thanks.
hi there i had a suzuki vs700 with the same problem, it turned out to be a fault on the fuel pump, it was intermitant, it was feedind one pot but staved the other, your problem really sounds formilar, you might need new fuel pump
dudds1960 is offline   Reply With Quote
Thread Tools
