| First Bike / New Rider This is the place new riders and first time bike buyers can get help from community experts |
#1 |
Master At Arms
what is it and what does it do?
#2 |
A power commander is a electronic device that uses different settings to affect ignition timing, fuel flow, etc to change the performance of the engine.
You can use it for fuel economy, or HP boosts.
Her profile said 5 11.....yeah lbs. |
#3 |
Administrator
It's most often used to adjust the fuel mixture when replacing the stock pipes with aftermarket exhaust. This only applies to computer-controlled fuel injected bikes of course. With carbs, the jets usually need to be replaced.
#4 |
Veryfried
yup. fi only! unless you have lots of money to waste!
easy to fit - easy to set up. theres different mappings available for different bikes with different exhaust / intake setups. as said, all it does is try to get 13:1 air:fuel ratio so can improve power output / delivery and fuel economy - depending how you ride ![]() you can attach them to your pc / laptop and upload custom maps, or use the buttons on the front to modify parameters. check out the webby - http://www.powercommander.com/powerc...r/default.aspx a must (imo) if you intend to change the pipes or intake on a fi bike. example - below are maps for a 2005 kawasaki zx10 with various mods. just download them, install to the pc3 and off you go ![]() Map # Map Description M212-ALL All Maps M212-529 European model, Bos Superbike open slip on, Stock air filter M212-528 European model-MIVV full Racing exhaust (Db Killer removed), Stock or aftermarket air filter M212-527 European model-MIVV full exhaust CE approved (Db Killer installed), Stock or aftermarket air filter M212-526 European model-Arrow slip-on exhaust and link pipe with baffle, Stock or aftermarket air filte M212-525 European model-Arrow slip-on exhaust with link pipe, Stock or aftermarket air filter M212-524 German model Leovince Racing slip on Stock or aftermarket Air filter M212-523 European model Shark R & D 4-2-1 full racing exhaust Db killer installed Stock or aftermarket air filter M212-522 European model Shark R & 4-2-1 full racing exhaust Stock or aftermarket air filter M212-521 European model Yoshimura TRS slip-on exhaust and link pipe Stock or aftermarket air filter M212-520 European model Leovince Racing slip-on with High link pipe Stock or aftermarket air filter M212-519 European Model, Shark F1 full exhaust and Stock or aftermarket air filter M212-518 European Model, Akrapovic ECE approved slip-on exhaust and Stock or aftermarket air filter M212-517 European Model, MHP full exhaust and Stock or aftermarket air filter M212-516 European Model, Arata full exhaust and Stock or aftermarket air filter M212-515 European Model, Blue Flame EVO slip-on exhaust (baffle removed) and Stock or aftermarket air filter M212-514 European Model, Leo Vince open slip-on exhaust and Stock or aftermarket air filter M212-513 European Model, Sato Racing open slip-on exhaust and Stock or aftermarket air filter M212-512 European Model, Arrow full exhaust with Road/Track silencer (baffle removed) and Stock or aftermarket air filter M212-511 European Model, Arrow full exhaust with Road/Track silencer and Stock or aftermarket air filter M212-510 European German Model. Akrapovic ECE approved slip on and Stock or aftermarket air filter M212-509 European Model. Micron high mount slip-on exhaust (retains stock exhaust valve) and Stock or aftermarket air filter M212-508 European Model. Micron Serpent full exhaust and Stock or aftermarket air filter M212-507 European German Model. Akrapovic Racing Line full exhaust and stock or aftermarket air filter M212-506 European German Model. Stock exhaust with catalytic converter and stock or aftermarket air filter M212-505 European Model. Laser Works full exhaust with Hot Cam silencer and stock or aftermarket air filter M212-504 European Model. Carbon Can Company race slip-on exhaust and stock or aftermarket air filter M212-503 European Model. Akrapovic open slip-on exhaust and stock or aftermarket air filter M212-502 European Model. Akrapovic Evo 2 full exhaust and stock or aftermarket air filter M212-501 European Model. Completely Stock Bike Last edited by benny hedges; 11-20-2009 at 01:20 PM.. |
#5 |
Administrator
It re-maps the air/fuel mixture for your bike, a wonderful tool in the hands of someone who knows what they are doing and with a dyno....Easy to install and dollar for dollar the best upgrade on HP for the money
#6 |
Master At Arms
What is a dyno?
#7 |
Administrator
#8 |
Manbear
What is a dictionary?
YUP! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
