Old 11-17-2009, 09:53 PM   #1
subhuman
subhuman's Avatar
subhuman is on a distinguished road
Default Fuel leak (86 Shadow)
Hey guys
So my buddy has an 86 Shadow VT700c, he got it for about 2 grand and its in good shape (IMO he paid too much) The handlebars seem to be turned slightly the wrong way, if you're going straight it feels like your hands are pointed slightly to the left. I laughed at him for a while and we added it to the list of things that need to be fixed. However, after we got it home we noticed it was leaking fuel. Badly. Major bummer. Its not from the tank and the fuel lines to the carbs are dry. We can't seem to find the source of the leak...I think it might be a reserve tank although I'm no expert and I'm %100 sure it has a reserve tank. I'm looking for ideas as to how we can go about fixing this.
I have a couple, the first was letting it run out completely, letting it dry, juice it up and try to find the source of the leak so we can JB weld it.
The second was to figure out a way to bypass the reserve tank.
Any thoughts?
Semper Fi
subhuman is offline   Reply With Quote
Old 11-27-2009, 09:49 PM   #2
HondaIlya
HondaIlya is on a distinguished road
id get my money back
HondaIlya is offline   Reply With Quote
Old 11-28-2009, 10:11 AM   #3
Munkey990
Munkey990 is on a distinguished road
I think this model had 2 gas tanks. Not really a reserve tank exactly but an extra tank under the seat that just increases the fuel capacity since the normal tank is kinda small for styling purposes.
If he purchased the bke from a dealer in used bikes, I'd agree with HondaIlya, take it back where you got it. If he purchased it from an individual, that's probably not an option.
The only thing I see to do is start disassemling until you find the source of the leak. It's probably in one of 4 places.
1. One of the 2 tanks as you've already addressed.
2. The petcock could be leaking and need to be rebuilt.
3. A fuel line could have a crack in it. They do dry out and crack and need to be replaced occasionally.
4. The carbs themselves could be leaking.
Munkey990 is offline   Reply With Quote
Old 12-01-2009, 02:07 PM   #4
subhuman
subhuman's Avatar
Thanks for the input munkey. I'll have him over this weekend and we'll tear it down to find the source, I'll take pictures.
Semper Fi
Old 12-01-2009, 03:26 PM   #5
68BS90
Master At Arms
68BS90 is on a distinguished road
Does it leak with the petcock turned off? Could be the carb float valve not shutting off. Follow the overflow tube and see if it ends right above the puddle. I'd start with the petcock. If the leak stops when it's off, probably the carb(s). If it leaks when it's on, but not on reserve, I'd check the valve and if it leaks whether it's off, on or res, then it's probably the valve or upstream.
68BS90 is offline   Reply With Quote
Search this Thread:
Advanced Search
