Old 09-18-2009, 07:08 PM   #1
philipk65
Motorcyclist
philipk65 is on a distinguished road
Default 1985 Nighthawk S Carb Issues
Hi, I have a 1985 Nighthawk S with 1000 miles on it. It's sat for a while. I took the carbs apart and cleaned them. I starts right up and runs great in the higher RPM range (4K- and above) and idles fairly descent. It's the 2K-4K rpm range that it sputters and is sluggish. What can I do to correct the problem? Thanks! Kevin
philipk65 is offline   Reply With Quote
Old 09-20-2009, 08:23 PM   #2
pidaster
Motorcyclist
pidaster is on a distinguished road
If you leave the choke about halfway does it help?
pidaster is offline   Reply With Quote
Old 09-20-2009, 11:26 PM   #3
philipk65
Motorcyclist
Yes, It helps alittle bit.
Old 09-20-2009, 11:31 PM   #4
pidaster
Motorcyclist
Sounds like it's running a bit lean. I'm no expert on carbs but you might have to shim the needle a bit. I had to do the same on mine. It had a flat spot around 3k-4500.
Search this Thread:
Advanced Search
