Old 09-13-2009, 06:45 PM   #1
scott1792
scott1792 is on a distinguished road
Default Oil everywhere
So I fired up my 1985 Honda Nighthawk this morning, and it didn't go so well. I tried to start it about 10 times, and it just kept dying if i let it go under 4000 RPMs and it made a weird clanking noise. After about the 10th try, I looked down, and there was oil everywhere. I looked to see where it was coming from, and I can't seem to find a definite place, but it looks like it is coming from deep within the engine. Does anyone know what happened?
scott1792 is offline   Reply With Quote
Old 09-15-2009, 07:43 AM   #2
Dodger
Bald Headed Fat Man
Dodger's Avatar
Dodger is on a distinguished road
That doesn't sound good. Have you checked your drain plug and made sure that your dipstick is not loose? Check your oil filter and lines to make sure that nothing is punctured. At 4000rpm, it will throw oil everywhere, so even the smallest hole will look real bad.
Dodger is offline   Reply With Quote
Old 09-15-2009, 06:42 PM   #3
scott1792
I just went to check the oil, and when I opened the oil cap, oil flew everywhere again. Is this normal?
Old 09-15-2009, 08:56 PM   #4
Dodger
Bald Headed Fat Man
Dodger's Avatar
Over filled maybe? Stupid question, but the bike wasn't running when you took the oil cap off was it?
Old 09-15-2009, 09:00 PM   #5
scott1792
The bike was not running. Is it possible that it built up a good deal of oil pressure?
Old 09-15-2009, 09:31 PM   #6
rexmitchell
Administrator
rexmitchell's Avatar
I don't think there would have been a lot of built up pressure, I would suggest draining all the oil, cleaning up the spilled oil and see if you can find the leak that way.
Old 09-15-2009, 09:41 PM   #7
Schneiderman
Schneiderman's Avatar
Schneiderman will become famous soon enough
If it came out the filler cap it would seem it's grossly overfilled, which could cause a blown head gasket as well as a failed oil pump- and a failed oil pump that goes undetected will grenade your engine after you fix the headgasket and go for a ride (ask me how I know).
Schneiderman is offline   Reply With Quote
Search this Thread:
Advanced Search
