Old 07-10-2009, 02:35 PM   #1
phil823
phil823 is on a distinguished road
Default bike runs but poorly
Bike Information:
1983 GR650 "tempter"
2 cyclinder, 4 stroke, DOHC, Inline engine
16k Miles
Top end rebuilt, carbs rebuilt, valve clearances stock? (have not looked at them they say adjusting isnt needed till 25k).
foam UNI filters installed
New Nology Coils installed
All else stock
i had these problems before the new Filters and Coils.
bike starts no problem.
bike will accelerate to 80mph (top is 102. and im a big guy so thats ok i guess)
bike is getting 25mpg!!
Issues!:
right plug fouls VERY quick, like 5 min or so.
after checking it after a run of higher speed, 45+ MPH, the top turns a tannish but everything else is still sooty black.
only getting 25mpg! should be getting 40!
backfires through carb, but i believe thats cause the left is running a little lean.
bike has an off idle. the right side sounds like its skipping or rushing to catchup up every few seconds. im guessing due to fouled plugs, spark is weaker.
anything past 1/2 throttle bike RPM goes up but there is no acceleration. can this be caused by running to lean possibly?
the bike has had these issues forawhile, and i thought new coils would fix it, but it did not. any ideas?
im stumped.
on the 21st a local shop is putting my bike on the DYNO to get the lean issues all fixed. is there anything else i should look at or tell them to look at? im stumped and i just want a running bike
phil823 is offline   Reply With Quote
Old 07-10-2009, 04:01 PM   #2
slumlord
slumlord's Avatar
slumlord will become famous soon enough
does this shop do carb synching?
slumlord is offline   Reply With Quote
Old 07-11-2009, 12:46 PM   #3
phil823
yes, but my carbs only have 1 vacuum port that the old petcock used to use.
Old 07-28-2009, 09:44 PM   #4
ballardchris84
Newbie
ballardchris84 is on a distinguished road
the top end was rebuilt? were the valves replaced? if not, that could be the problem.
did the shop get your problems all fixed or find a cause?
ballardchris84 is offline   Reply With Quote
Old 07-29-2009, 04:17 AM   #5
phil823
looked into the problem furthur. i leaned the right side out so far that it was carb backfiring.
it ends up it was oil fouling!
i got a valve job and new piston rings.
atm im working on shimming. after the work the sizes are quite a bit different.
Search this Thread:
Advanced Search
