Old 06-10-2009, 01:41 AM   #1
iTrek
Master At Arms
iTrek is on a distinguished road
Default How do you turn off your motorcycle?
I use the kill switch.But I have heard you shouldn't use it because it could wear it out, or drain the battery somehow.
iTrek is offline   Reply With Quote
Old 06-10-2009, 02:05 AM   #2
MS_Steve
MS_Steve is on a distinguished road
Default To Kill or Not to Kill... switch
My bike has a key... I usually turn the key to the OFF position.
But I've been known to flip the Kill Switch, if my hands are pre-occupied doing something else.
I'd think a kill switch would be rated for several thousand flicks, I've never heard of one wearing out, from over-use.
MS_Steve is offline   Reply With Quote
Old 06-10-2009, 02:46 AM   #3
AngryHatter
AngryHatter's Avatar
AngryHatter is on a distinguished road
I put the kickstand down.
AngryHatter is offline   Reply With Quote
Old 06-10-2009, 05:45 AM   #4
SuperSherpa197
The Cool Joker
SuperSherpa197's Avatar
SuperSherpa197 is on a distinguished road
stop, take bike out of gear, turn off key.
inb4 lulzparkyourbikeingear
that always comes up at bike night. i guess i'm just backwards, i park my manual car in gear yet i park the bike in neutral. i figure if it's gonna fall over it's not gonna be likely due to it not being in gear
'03 YZF600R, 61k miles
SuperSherpa197 is offline   Reply With Quote
Old 06-10-2009, 06:55 AM   #5
Dodsfall
Administrator
Dodsfall's Avatar
I do the same thing.
2008 XL1200R
Old 06-10-2009, 08:19 AM   #6
Dan631
Paramedic
Dan631's Avatar
Dan631 is on a distinguished road
If the kill switch wears out, replace it like you would any other part on the bike that has come to the end of it's life. The kill switch isn't going to drain your battery. Using it to cut spark to the motor and leaving the ignition switch on is what is going to drain the battery.
Dan631 is offline   Reply With Quote
Old 06-10-2009, 08:50 AM   #7
Dodger
Bald Headed Fat Man
Dodger's Avatar
Dodger is on a distinguished road
I generally put the bike in neutral and use the key. I rarely use the kill switch.
Putting the kick stand down while in gear will kill the bike too.
Dodger is offline   Reply With Quote
Old 06-10-2009, 09:01 AM   #8
cdillon23
cdillon23's Avatar
cdillon23 is on a distinguished road
I stop the bike, put it in neutral, hit the kill switch and turn off the key. I have small kids so I always use the kill switch in case they ever find the key and get mischievous.
My Ride--None
cdillon23 is offline   Reply With Quote
Old 06-10-2009, 09:09 AM   #9
cbdallas
cbdallas's Avatar
cbdallas will become famous soon enough
I make it a point to never use the kill switch, because at 6:40 in the morning when I stumble out to the garage to ride to work and the bike refuses to start, I spend 3-4 minutes cussing under my breath while looking for the problem, and find the kill switch is off.
cbdallas is offline   Reply With Quote
Old 06-10-2009, 09:17 AM   #10
ILoveWookiees
ILoveWookiees is on a distinguished road
Lol yeah I've done that loads and then my mates like check the killswitch...... ohhhhh lol. It's like when I did my test 3 years ago I'm so used to my bike not being able to move if you've got the stand down. So on my test I was on a different bike and it didn't do the same thing so I went straight off with my stand down and only realised cause my training instructor that brought me there pointed it out. Luckily the test guy didn't see and I get back and the training instructor I've been with for 2 days previous says to me you do that every time and you never learn lol.
Just some things like the killswitch I never get into my head.
ILoveWookiees is offline   Reply With Quote
Old 06-10-2009, 09:23 AM   #11
pdksh
Master At Arms
pdksh's Avatar
pdksh is on a distinguished road
I, generally, use the kill switch.
pdksh
2000 Suzuki Intruder VS800
pdksh is offline   Reply With Quote
Old 06-10-2009, 09:29 AM   #12
YamahaFan
Certified Homeless Biker
YamahaFan's Avatar
YamahaFan is on a distinguished road
Bike is stopped, I leave it in gear if it's on a slope otherwise neutral it is. Hit the killswitch, turn off key and lock it and put the kick stand down.
When I turn it on I always do the opposite: turn on the key, turn on the killswitch (or is it turn off since it said "kill"?), look at the neutral light and start the bike.
1996 Yamaha FZR600, first and current bike, and loving it. RIP Pat Taylor aka iamgumby
I'm into women in leather. No whip please. It's not my style.
YamahaFan is offline   Reply With Quote
Old 06-10-2009, 09:33 AM   #13
japac1
Motorcyclist
japac1's Avatar
japac1 is on a distinguished road
japac1 is offline   Reply With Quote
Old 06-10-2009, 09:40 AM   #14
ILoveWookiees
Isn't the Killswitch bad for the electrics? When doing my training upto my test a few years ago I was taught that it's only there for emergencies, if used too much it can bugger up the electrics and you should always turn it off via the key.
Old 06-10-2009, 10:31 AM   #15
LethalThreat
Riding For Relaxation
LethalThreat's Avatar
LethalThreat is on a distinguished road
I typically just turn the key off. I leave the bike in gear on hills with the kickstand down. On level ground, I leave it in neutral and put it on the center stand.
1982 Honda CB750SC Nighthawk
CTRiders.org
LethalThreat is offline   Reply With Quote
Old 06-10-2009, 10:36 AM   #16
YamahaFan
YamahaFan's Avatar
I believe the killswitch is just to cut off the electric power to the engine, nothing more, so, basically it's just a switch, it can wear out. Can someone prove me wrong so I can do it right next time?
Old 06-10-2009, 10:50 AM   #17
Tdubb
Super Moderator
Tdubb's Avatar
Tdubb is on a distinguished road
Oh, man, I never thought about that. I always use the key, and park it in the garage in neutral. And leave the key in it. I think I will start using the kill switch.
Although they know, if they mess with my baby, they might just draw back a nub.
Tdubb is offline   Reply With Quote
Old 06-10-2009, 10:52 AM   #18
InfiniteMiles
InfiniteMiles's Avatar
InfiniteMiles is on a distinguished road
Well I make it a point to always use the killswitch, leave the bike in gear and turn off the fuel. So when I'm gone for a week or exhausted in the morning it's second nature to go through the motions.
You must live in a great neighborhood, I would never do that where I live.
InfiniteMiles is offline   Reply With Quote
Old 06-10-2009, 11:00 AM   #19
Rich22
Rich22 is on a distinguished road
The kill switch is no different than turning the key off, or putting the kick stand down with the bike in gear. As far as the bike is concerned, all of those actions create an open circuit. As others have said, it is just an electrical switch.
In my BRC, we were told that using the "engine cut off switch" (they didn't like the term "kill switch") was the proper way to stop the engine.
I don't really buy into that being the "proper" way to shut down the bike but it is the way I do it. Since I always shut down the bike with the kill switch, it is a habit to flip it to the run position before I start the bike so I really don't have to worry about the bike not starting due to the switch being off.
Rich22 is offline   Reply With Quote
Old 06-10-2009, 11:32 AM   #20
skooter Bum
skooter Bum is on a distinguished road
Turn the ignition switch off, turn the fuel off, then the kill switch. If that doesn't work,...then I shoot it!
skooter Bum is offline   Reply With Quote
Old 06-10-2009, 11:53 AM   #21
iamjustifyd
iamjustifyd's Avatar
iamjustifyd will become famous soon enough
Bike in nuetral, switch, key to off and lock handlebars. In class we were taught to always!! use the switch.
Sherry 2005 Honda Spirit 750 DC
iamjustifyd is offline   Reply With Quote
Old 06-10-2009, 12:06 PM   #22
InfiniteMiles
I leave my bike in gear,so it won't roll away. It won't start with the clutch out or the stand down in gear so I have no worries of launching in to the back of my garage.
Old 06-10-2009, 12:29 PM   #23
NoRegrets78
NoRegrets78's Avatar
NoRegrets78 is on a distinguished road
Bike in neutral, kill switch, then key.
Just the way I was taught in the MSF.
2009 Kawasaki Vulcan 900 Custom
NoRegrets78 is offline   Reply With Quote
Old 06-10-2009, 01:37 PM   #24
Goliath616
Goliath616's Avatar
Goliath616 has a spectacular aura about
I leave it in gear, hit the kill switch, then reach up to the neck of the bike and turn off the key
'08 Yamaha Road Star
Goliath616 is offline   Reply With Quote
Old 06-10-2009, 02:37 PM   #25
Sed8Me
Comfortably Numb
Sed8Me's Avatar
Sed8Me is on a distinguished road
The dealership and the owners manual say to use the key and not the kill switch... I dont know why, and cant figure the logic... but I do it that way because, "they told me to"
Sed8Me is offline   Reply With Quote
Old 06-10-2009, 02:44 PM   #26
rexmitchell
Administrator
rexmitchell's Avatar
I use the key, I never bother with my kill switch.
Old 06-10-2009, 03:21 PM   #27
Dan631
Paramedic
Dan631's Avatar
All the killswitch does is redirect the current going to the coils and sends it to ground to put it simply. Knowing what I know about motorcycle electrical sytems I don't see a killswitch buggering up anything. Nor have I experienced any electrical problems directly related to the use of a killswitch.
Old 06-10-2009, 03:25 PM   #28
bajakirch
bajakirch's Avatar
bajakirch is on a distinguished road
I just reverse the start-up steps (FINE-C) taught in the MSF/BRC:
C = Clutch in
E = Engine Shut-Off Switch
N = Neutral
I = Ignition
F= Fuel Supply Valve
bajakirch is offline   Reply With Quote
Old 06-10-2009, 03:31 PM   #29
Tdubb
Super Moderator
Tdubb's Avatar
So basically you turn the bike off, put it in neutral, start it back up, and then turn off the fuel valve?
Old 06-10-2009, 03:34 PM   #30
rexmitchell
Administrator
I never use my fuel cut off valve
Old 06-10-2009, 05:11 PM   #31
primalmu
2005 Bandit 1200S
primalmu's Avatar
primalmu is on a distinguished road
I park, hit the kill switch, then release the clutch, roll the bike forward a bit, and put down the kickstand. Might seem odd, but the kickstand on the Katana isn't of the greatest design. I keep the bike in gear and pushed forward so no on accidentally moves the bike forward and collapses the kickstand.
primalmu is offline   Reply With Quote
Old 06-10-2009, 05:34 PM   #32
InfiniteMiles
It's because the kill switch wears out much faster than the Ignition. A kill switch is not designed to be switched nearly as many times as they are and will wear out long before an ignition, however they are much easier and cheaper to replace.
Old 06-10-2009, 06:37 PM   #33
louturks
louturks's Avatar
louturks is on a distinguished road
I use kill switch
louturks is offline   Reply With Quote
Old 06-10-2009, 07:33 PM   #34
piranha2
Master At Arms
piranha2 is on a distinguished road
In my MSF course, they told us that it doesn't matter how you shut your bike off. They said the kill switch should be off when you turn on the key to start the bike. Something like a "soft start" for the computer and electronics. I always use it after that.
piranha2 is offline   Reply With Quote
Old 06-10-2009, 08:02 PM   #35
HKshooter
HKshooter is on a distinguished road
I never use the kill switch. My car doesn't have one, truck don't have one. I personally think the obsession with the thing is silly. Seems some folks just have to use it because it's there.
I don't turn off my fuel either. Never had a problem. I was taught the kill switch is there to give the rider an easy and quick way to kill the engine in the event it goes down with him on it and in gear. Been said that a bike in gear on the ground can grind a guy into the pavement.
HKshooter is offline   Reply With Quote
Old 06-10-2009, 08:12 PM   #36
bajakirch
bajakirch's Avatar
I = (Turn Off) Ignition
Old 06-10-2009, 08:35 PM   #37
Chuck A
bikes and corvette
Chuck A's Avatar
Chuck A is on a distinguished road
Kill Switch
I enjoy nice, and fast , women and vehicles, LOL
Chuck A is offline   Reply With Quote
Old 06-10-2009, 08:37 PM   #38
primalmu
2005 Bandit 1200S
primalmu's Avatar
Until the float valves in your carbs stop seating well and you end up flooding your crankcase with gasoline...
Old 06-10-2009, 09:12 PM   #39
ocyshp
Master At Arms
ocyshp's Avatar
ocyshp is on a distinguished road
Was told in the motorcycle safety course to use the kill switch.
Some people live, some exist and others........
ocyshp is offline   Reply With Quote
Old 06-10-2009, 10:29 PM   #40
bikejockey
bikejockey is on a distinguished road
use the key that is what it is for just like in your cage. The kill switch is for an emergency. I do use it though if i don't want to get the key back out of my pocket to turn the bike back on you know like if i stop to talk to someone for a min. or so.
bikejockey is offline   Reply With Quote
Search this Thread:
Advanced Search
