Home built exhaust question - Motorcycle Forum
Go Back   Motorcycle Forum > Motorcycle Repair, Building, and Restoration > Building, Restoration & Modification
Building, Restoration & Modification Building a bike, restoring a classic, or making some modifications?
Thread Tools
Old 05-02-2009, 08:16 AM   #1
JohnnyRingo
JohnnyRingo is on a distinguished road
Default Home built exhaust question
Just a brief question for the DIY's among us. If you have the equipment to bend/cut/weld pipe at home, how tough is it to actually build your own exhaust system? Seems like a lot of basic parts aren't terribly difficult, just time consuming and equipment-intensive. Is this the case with exhaust? Just curious. Thanks for any feedback.
-R.
JohnnyRingo is offline   Reply With Quote
Old 05-02-2009, 01:08 PM   #2
Zuki
Master At Arms
Zuki's Avatar
Zuki is on a distinguished road
Yep it's the same with making any custom work always measure twice and cut/bend once.
Take it slow and enjoy the ride
Zuki is offline   Reply With Quote
Old 05-02-2009, 02:32 PM   #3
AlphaZed
AlphaZed's Avatar
AlphaZed is on a distinguished road
What kind of bike is it going on? Is it carbureted or injected? And is the goal performance or looks?
AlphaZed is offline   Reply With Quote
Old 05-02-2009, 02:53 PM   #4
JohnnyRingo
Going on an '06 suzuki s40. And the ideal purpose is aesthetics. I think the stock pipes look a little anemic. Not to mention they are dented to hell from the wreck.
-R
Old 05-02-2009, 03:23 PM   #5
AlphaZed
AlphaZed's Avatar
-R
The S40's injected, right? Can you get a PowerCommander or other ignition mapping device for it? I don't know cruisers, but I'm sure you wouldn't want the bike to run like crap, load up or burn a piston...
Old 05-02-2009, 03:46 PM   #6
JohnnyRingo
Yea I've done enough to hurt that poor bike already. I'm guessing the ignition mapping would....what? Tell me whether or not I need a special consideration or considerations for what I can throw on it?
-R.
Old 05-02-2009, 04:56 PM   #7
primalmu
primalmu's Avatar
primalmu is on a distinguished road
The S40 is NOT fuel injected. If you build a custom exhaust you will have to rejet the carb.
2003 Suzuki Bandit 1200 (naked) - SOLD
1984 Honda Gold Wing GL1200 (stripped)
primalmu is offline   Reply With Quote
Old 05-02-2009, 05:26 PM   #8
AlphaZed
AlphaZed's Avatar
-R.
Changing pipes will change the way the bike breathes. A PowerCommander (PC) would allow you to adjust the fuel mix accordingly. On fuel injected bikes, whenever you change intake or exhaust, 90% of time they need to be remapped...
With an aftermarket pipe and a PowerCommander, you can usually download the correct map and upload it to your bike. With a custom pipe, like you're proposing, you'd likely need to get the bike dyno'ed to net the correct map. Without a PC or other ignition mapper though, how the bike ran would be a crap-shoot!
Old 05-02-2009, 08:14 PM   #9
JohnnyRingo
Thanks Prim. I had totally neglected the question. Essentially rejetting the carb would have the same net effect as mapping the ignition and all, right? I mean, ultimately I have to change up the fuel mix? Which is more of a pita, the powercommander route, or the rejet?
-R.
Old 05-02-2009, 09:23 PM   #10
AlphaZed
AlphaZed's Avatar
Cool! Jets are cheaper than a PowerCommander!
Old 05-02-2009, 09:53 PM   #11
JohnnyRingo
Any tutorials anywhere about how to go about jetting a carb?
(The noob questions keep on comin'!)
-R.
Old 05-02-2009, 10:05 PM   #12
skooter Bum
skooter Bum is on a distinguished road
What type of bending machine do you have? If it can't do mandrel bends,...your waisting your time. Unless you just what to say I did it myself.
skooter Bum is offline   Reply With Quote
Old 05-03-2009, 09:10 PM   #13
primalmu
primalmu's Avatar
This is a null point, since you don't have the option of the PowerCommander.
I personally don't know how easy it will be. It will certainly be trial and error to get the fuel mix right. The good news is you only have one carb to deal with.
Old 05-03-2009, 11:35 PM   #14
AlphaZed
AlphaZed's Avatar
-R.
Ya know... Jetting the carb is gonna a walk in the park compared to building your own exhaust.
I know my way around bikes pretty well and have jetted and remapped many, but I would NEVER try to engineer and build an exhaust system myself! That's WAAAY over my head!
Old 05-04-2009, 09:15 AM   #15
Dodsfall
Administrator
Dodsfall's Avatar
Dodsfall is just really nice
-R.
Changing the jets is for carbed bikes, the power commander changes the computerized fuel mixture in electronic fuel injected bikes.
2008 XL1200R
Old 05-05-2009, 09:52 AM   #16
tigett
Slow Down.. You'll See More
tigett's Avatar
tigett is on a distinguished road
youtube has a couple tutorials on rejetting. it seem intimadating, but i did it and i'm dumb!. take yer time and dont loose any parts! ha
tigett is offline   Reply With Quote
Thread Tools
