#1 |
Can anyone tell me how to do a bench test for a rectifier/regulator out of a
1983 vt750 honda shadow,Step by step using a multimeter tksPicture 054.jpg 3 yellows wires going to stator and 2 green 2 red/white and 1 black going to the harness for the rectifier |
#2 |
Well, that was what I had. My neighbor tested it for me and determined it to be bad.
So I got a junkyard replacement. Test procedure ought to be in the mechanics manual. They are in some libraries. Or a general test procedure. Good luck. dc |
#3 |
Paramedic
When you test a rectifier you are testing the diodes in it. Set your meter to the diode test setting. You want to test the continuity between the POS wire and the three yellow wires, then the NEG wire and the three yellow wires.
For example, put the NEG lead of your meter on the POS wire on the rectifier and with the POS lead of the meter touch each of the yellow wires one at a time. If you have continuity through all three yellow wires swap the meter leads so the POS lead is now on the POS wire and with the NEG lead touch the three yellow wires. You should have no continuity. Now do the same thing with the NEG wire of the rectifier. |
#4 |
Tks for the help.Dumb question,
My meter shows diode testing in volt and ohms Am i testing in with the meter on ohms and diode orVoltage and diode.And on the picture pos is red wire and green is neg right,Tks |
#5 |
Disregard my last thread,Tks again Dan for the info
Heres what happened. The first test i put the NEG lead of my meter on the POS wire on the rectifier and with the POS lead of the meter touch each of the yellow wires one at a time. I had continuity i reversed them and had no continuity. So far so good But when i tested the neg wire with my pos lead i got no continuity touches 3 yellow wires. And with neg lead touching 3 yellow wires i got continuity So does this mean my rec is good? And is this test 100 percent |
#6 | |
Paramedic
#7 | |
