Old 04-23-2009, 10:30 AM   #1
SkinnyDave
Master At Arms
SkinnyDave is on a distinguished road
Default Replaced gaskets on petcock, made leaking worse!!
Original petcock on 1983 750 Maxim... Before it was leaking from the square back plate (vacuum valve) i THINK... though it's really difficult to tell with gasoline in a tiny cranny like that. It just started leaking a few weeks ago.
I was in the process of sealing the tank from rust so I bought new gaskets/valve rubbers for the petcock while I had the thing off.
I replaced the internal rubber of the thing, and also the O-ring that seals it against the tank. But now it's leaking from its seal against the tank.. or maybe from EVERYWHERE.. I can't tell... but when I get that thing on there tight, making sure the gaskets are fairly square, no chunks of debris in the way, and turn down the screws TIGHT... it still leaks like a bloody nose... from the top.. I mean the whole thing is covered in fuel and dripping willy nilly. Needless to say my driveway was a bit of a fire hazard last night
Is this an issue like ... I gotta let the thing sit in place for a day or two before the gaskets "mold" into place and "seal up"?? or is it just that dodgy trying to repair a petcock?? Anything I can do?
New one is $125 and I wouldn't really trust one from ebay...
The weather is getting SUPER beautiful and I'm almost reduced to tears cause I can't ride. I've been wanting to skip town on my bike for WEEKS and I've had to deal with tons of ridiculous bullplop like this.
thanks
-David
SkinnyDave is offline   Reply With Quote
Old 04-23-2009, 07:47 PM   #2
tylernt
Special Member
tylernt's Avatar
tylernt is on a distinguished road
I hate Yamaha petcocks. They belong in the trash, good riddance. Got myself a Yamaha adapter plate which takes a standard threaded petcock, and of course a universal manual petcock to go with it. Nice thing about the adapter plate is you can then buy any inexpensive and easily obtained 3/8" NPT petcock you want. I got an earlier version of the petcock shown here: https://www.partsnmore.com/cat_index...&category=carb. It's been trouble-free for a couple of years now, I'm very pleased with it.
I'm not sure if all Yamahas take 46mm adapter plates, they probably do -- best to double-check if you're thinking about getting one though. FYI you will have to Dremel out a little bit of metal from your tank's petcock opening, I filled mine with water during this operation to avoid a minor gasoline explosion.
'07 Ninja 500R, formerly '81 Yamaha XS400
tylernt is offline   Reply With Quote
Old 04-24-2009, 05:53 PM   #3
SkinnyDave
Master At Arms
Whoa thanks!!!! This should solve the problem rather nicely.
Though, I notice that this is a simple non-vacuum petcock. Does that mean it simply relies on the float needles to stop fuel flow? Also, what positions does the valve have? Just on/off? Hopefully there's an "off" for when you disconnect the hose
BTW, I managed to solve the leak for now!! GOD I'M STOKED!! NOW I CAN RIDE. All I did was replace the (brand freaking new OEM, ahem) O-ring that seals the **** against the tank with the old one.. I put the original one back on there, which had crud stuck to it! But it wasn't the o-ring that was leaking originally, so apparently it was still good enough for the task at hand. (and not the freaking new one I spent $$ on .. thanks Yami)
Old 04-24-2009, 05:54 PM   #4
SkinnyDave
Master At Arms
um.. that "****" up there was just the word petcock minus pet ... hahaa .. oops...
Old 04-24-2009, 07:06 PM   #5
tylernt
Special Member
tylernt's Avatar
There's Off, On, and Reserve. I turn mine Off after every ride and On before, but I suppose you could leave it On all the time if you trusted your float valves.
Glad you got yours working though...
Old 04-25-2009, 11:06 AM   #6
SkinnyDave
Master At Arms
cool, thanks
Search this Thread:
Advanced Search
