Old 03-28-2009, 01:58 PM   #1
gueedo70
gueedo70's Avatar
gueedo70 is on a distinguished road
Default Overtight?
Alright well I successfully removed and reinstalled my first motorcycle wheel. I have just one concern. I torqued the axle nut to spec but then the notch on the axle nut and the cotter pin hole didn't line up so I tightened the nut a little more to line them up. I was wondering if that would have any kind of detrimental effect on my bike...or me.
2009 Suzuki SV650SF -- Silver
gueedo70 is offline   Reply With Quote
Old 03-28-2009, 02:18 PM   #2
primalmu
2005 Bandit 1200S
primalmu's Avatar
primalmu is on a distinguished road
I don't bother torquing the axle nut. I'll just tighten it up real good (almost completely tight) then tighten enough so that the carter pin lines up with its slot.
I was told not to worry about overtightening. I think the way the wheels and bearings are designed it's very hard to tighten it so much that it damages anything.
primalmu is offline   Reply With Quote
Old 03-29-2009, 01:03 AM   #3
wsideshow
Guest
Posts: n/a
If it is a little bit over tightened there won't be a problem.
Search this Thread:
Advanced Search
