Old 02-16-2009, 11:06 PM   #1
kocher101
kocher101 is on a distinguished road
Default I need some suggestions on my 1971 CS3 Rat Bobber project
I have an issue with my oil tank. The bike has a 200cc twin 2-stroke and I need a new oil tank to replace the one which was formerly in the side panel. I have turn it into a hardtail and don't have much room to work with but on the other hand the original oil tank only holds about a quart or so. Some small would be fine. The only tanks that I am finding are 3qt and bigger with multiple inlets/outlets for 4-stroke sportsters and such. The tank I need only needs one outlet and a breather cap according to what I can see on this original tank. Thanks a ton!! I was almost thinking that one of those new metal style water bottles would work by changing the cap and tapping a nipple into the bottom side or bottom even. Then I could attach it with a small fire extinguisher holder or something...maybe I could refab an old little fire extinguisher to work and turn the gauge into an oil gauge...hmmmm, that may work!?!?!?
kocher101 is offline   Reply With Quote
Old 02-17-2009, 09:42 AM   #2
Schneiderman
Schneiderman's Avatar
Schneiderman will become famous soon enough
Welcome to the forum! I've moved this to the repair forum where you are more likely to find help.
Big Government is a problem, not a solution.
Schneiderman is offline   Reply With Quote
Old 02-17-2009, 02:00 PM   #3
kocher101
Awesome, thank you!
Search this Thread:
Advanced Search
