Go Back   Motorcycle Forum > Motorcycle Forums > First Bike / New Rider > Buying First Motorcycle Soon
Old 02-12-2009, 12:56 AM   #1
spyderboy
spyderboy is on a distinguished road
Unhappy Qualities of a good helmet/which one should I get if I only have $100. PLEASE ADVISE
I'm a new rider, actually I don't have money for the rider's class yet. I'm saving up for the class and a helmet.
That being said, I'm searching for a full face helmet now. Can someone please give me advise on:
1. what to look for
2. which brand
3. where to get the best bang for the buck
I appreciate your help full-heartedly,
Spyderboy
spyderboy is offline   Reply With Quote
Old 02-12-2009, 06:01 AM   #2
PJL
Exorcising My Angels
PJL's Avatar
PJL is on a distinguished road
Go to different websites and see what you can get on clearance/closeout in your size.
www.motorcycle-superstore.com
www.revzilla.com
www.newenough.com
www.kneedraggers.com
Those four sites are good places to start.
As far as what to look for... Basically, at that price point, make sure it's DOT approved and has some type of ventilation. Anything beyond that is icing on the cake.
This is in the wrong forum, though; you should ask a mod to move it.
PJL is offline   Reply With Quote
Old 02-15-2009, 04:52 PM   #3
rexmitchell
Administrator
rexmitchell's Avatar
Im moving this to the "buying first motorcycle soon forum"
Old 02-15-2009, 06:20 PM   #4
Thekerrick
Thekerrick's Avatar
Thekerrick is on a distinguished road
The main things to look for in a helmet are the fit and pressure points.
If you go and test out helmets (which I recommend you do before you buy off line) make sure its very snug. Your cheeks need to be pushed in almost to the point where you bite them if you close your mouth. Have someone hold the helmet and move it back and forth while you keep your head and neck rigid. It should move very little.
As for pressure points make sure there is no "Ring of pain" as I call it anywhere in the helmet. By that I mean a ring of pressure on particular part of your head where you think a headache will happen after a bit of riding.
Also look for used helmets. I know everyone says not too but you can find some good deals on helmets that have barely been worn. Make sure you check out the used ones though to make sure they haven't been dropped and that they fit properly. NEVER wear a dropped helmet.
Hope that helps!
Thekerrick is offline   Reply With Quote
Old 02-15-2009, 08:13 PM   #5
Schneiderman
Schneiderman's Avatar
Schneiderman will become famous soon enough
A friend of mine just got a great deal from a place I had never heard of before, http://www.motorcyclecloseouts.com/
Check them out, here's a helmet that should be good for $100:
http://www.motorcyclecloseouts.com/s...met+-+black+2x
Otherwise I really like newenough.com and have used them for the majority of my gear purchases.
Big Government is a problem, not a solution.
Schneiderman is offline   Reply With Quote
Old 02-15-2009, 08:20 PM   #6
Dodsfall
Administrator
Dodsfall's Avatar
I bought my Bell brand full face helmet for $90 plus tax. No frills, just plain black and vented.
I would advise against a used helmet. If a helmet is dropped, it could have internal damage to the foam material that can't be seen from the outside. Helmets are built for one impact. The foam inside crushes and absorbs the blow, but it won't do it twice. I wouldn't risk my head to save $20.
2008 XL1200R
Old 02-15-2009, 09:00 PM   #7
SimonTuffGuy
i like to thump...
SimonTuffGuy's Avatar
SimonTuffGuy is on a distinguished road
I went with THH... Found a dealer on EBay that was selling them. I think I paid $80 and shipping.
Fit was good and it was Snell and DOT approved.
Don't go used... The padding inside conforms to YOUR head over time... A used helmet won't do that. Plus, as noted above, who knows if it has been dropped, etc.
Simon -
SimonTuffGuy is offline   Reply With Quote
Old 03-02-2009, 10:25 AM   #8
roflol
Warning: Mood change in 3... 2... 1...
roflol's Avatar
roflol is on a distinguished road
I live close enough to motorcyclecloseouts that I could try out what they had, and when I was looking last year they had a Zox full-face helmet for under $100, also my budget... it was comfy in the store (and they didn't mind me walking around in it). I have been pleased with it. It is vented at top and in front. The padding is removable for washing if necessary.
I was also pleased that when I got home with it the online professional reviews were favorable, stating that even though it didn't cost as much as some other helmets it was just as good.
The problem with getting a helmet online only without trying it on IRL first, is you just don't know if it'll fit and/or what size to get. Each helmet is going to fit differently - the day I was shopping, my head was a size M to XL depending on the helmet maker and model.
If you can, you really should find a place you can at least try them on. Good luck!
roflol is offline   Reply With Quote
Search this Thread:
Advanced Search
