| General Motorcycle Discussion If it doesn't fit in any of the motorcyle forums below, post it here. |
#1 |
Well having ridden in sup freezing temperatures I can say that all of the holes that air can get in are quite obvious. I thought I had all things patched up until I realized that, DUH!, my neck was freezing.
Anyone have any suggestions for a neck warmer/wind breaker. I cant find much just googling around. Ive heard of those tube thing's but they don't seem very warm. Im looking in a price range of 15-20 bucks. Perhaps im looking a bit too deep into this but will a scarf just work? |
#2 |
too slow
I like using one of these. Its just a fleece sleeve you can put around your neck.
http://www.motorcycle-superstore.com...eckgaiter.aspx |
#3 |
Administrator
I use a scarf to keep the wind out when it's cool outside. I just wrap it around and tuck the ends down the front of my jacket.
There are a lot of different neck warmers available from the tube type to ones that include a full face or head cover.
#4 |
Fallen Riders
My balaclava is so long that I can tuck it into my shirt. Even my "7-11" mask from Wally World is long enough to tuck in.
03 Suzuki GSF1200S Bandit, HIR headlights, GIVI shield, SWMoto guards, Hayabusa shock, lowered 2", H/S backrest & tailrack, Avon Storms, VStrom Hand Guards, IBA SS 1k |
#5 |
I recommend 4 wheels and windows in sub freezing temps
but when I just "have" to ride, my cotton skull mask (covers only the lower portion of my face) is long enough to tuck into my shirt and be covered by my coat
'08 Yamaha Road Star To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#6 |
Super Moderator
I bought a baclava for my wife at a local farm/ranch store. She gets cold easy, and claims it is just the perfect thing. I just use a larger bandana tied around my neck.
#7 |
Yes, a long balaclava. I have the Harley 98201-04V. $25. It is worth every penny.
http://www.amazon.com/Harley-Davidso.../dp/B000RY2S36 |
#8 |
I Ride Like A Girl
I like the Buff for cool weather.. they run around $20. I am not sure about sub freezing, i don't think they are thick enough. But they are versatile to pull up over your face, wrap your helmet hair in, etc.http://www.buffwear.com/
also some gear shops sell them. They are a nice high tech fabric that works for a variety of temps, but keep in mind I live in FLORIDA. |
#9 |
Out Standing In His Field
I use a neoprene ski mask that has a long enough neck it tucks into my jacket collar. That coupled with a good turtleneck shirt, the hands become the limiting factor.
#10 |
I use a $5 fleece scarf I bought from WalMart, with the ends tucked in. Granted, I live in Texas so the weather generally isn't chilly enough to need anything more...but as of this Thursday I'll be living in NJ so I might consider other options if the scarf doesn't work well enough!
#11 |
Hrmm so no problems with a scarf? Im also worried that a baclava will be too tight in my helmet. Thanks for the suggestions though ill def give them a look over.
#12 |
2005 Bandit 1200S
I love my Arctiva balaclava. Expensive, but worth its weight in gold on cold mornings.
#13 |
Administrator
A good balaclava will probably keep you warmer than a scarf. I haven't had any problems wearing a scarf.
#14 |
Grow a nice thick beard.....
It's the cheapest option. I ONLY have a scarf, and it helps, but not enough on certain coldy-cold days. dv |
#15 |
Guest
Posts: n/a
I've ridden as low as 20 degrees and never had a need for neck protection, I suspect its the huge windshield
#16 |
Dude I bought a knit beanie at Wal-Mart for $1. ONE STINKING DOLLAR! I cut the top off and it made a skin-tight scarf. No tail-ends flopping around, and it conforms to my face and neck. It looks pretty cool too before I put my helmet on, kinda like a ninja mask or something because I pull it up to my nose.
#17 |
Motorcyclist
i use the PHAROAH DELUXE BALACLAVA made by Schampa and it is awesome. no wind gets through it.
#18 |
Got an old wool hat - cut the top off and volia! Instant neck warmer. But a balaclava would be better and not that much more $.
#19 |
Master At Arms
Balaclava, a neck warmer that came with my jacket, and about a month's worth of stubble as a base layer.
But last I checked it was 5 degrees F with a high predicted of 15. |
