Home made bead breaker - Motorcycle Forum
Go Back   Motorcycle Forum > Motorcycle Repair, Building, and Restoration > How To
How To A forum for ideas and tips on how to make it happen
Thread Tools
Old 10-20-2008, 07:28 PM   #1
iamgumby
Fallen Riders
Default Home made bead breaker
I've known guys to use furniture clamps to break beads. I've seen guys step on them and break them loose. I know one guy that carried his off to a school playground and used a 'teeter-totter' to break his bead. This works for me.
Very straight forward. Very simple. And it works. I changed out a 180/55R-17 and a 180/70R-17 off mags without issues a week ago. Notice the multiple holes in the riser - that is your tire width adjustment. Customeize your spacing for your needs. Crib up the bottom side of the tire in both places where it rests on the deck with small blocks of 2x4 - and pay attention that it will not hit your rim. Press down slowly until the side walls squeeze together and meet; turn 90 degrees and repeat. The bead will break loose. Then it's rim protectors and tire levers to get the old rubber off the rim. Clean the inside of the rim thoroughly. Best practice is to replace the valve stem. Lever on the new rubber making sure the rotation arrow is corrrect. Balance and re-install. Balance? That's another article in the works.
Old 10-21-2008, 10:58 PM   #2
buellosaurusrex
Super Moderator
buellosaurusrex's Avatar
buellosaurusrex is on a distinguished road
That is really pretty ingenius...and clever, as well. Thank you for the pictures, too. I now know my next project......
buellosaurusrex is offline   Reply With Quote
Old 12-06-2008, 11:28 AM   #3
iamgumby
Fallen Riders
Default Another bead breaker option
Here is another bead breaker option! $8 each from Big Lots. Lots of guys use these and they can make a really effective pinch angle.
I mainly got these for re-installing the tire on the wheel because the tire likes to slide off the bead opposite of where you're trying to put it on ! This will hold him in place !
Old 12-06-2008, 09:32 PM   #4
briang
Guest
Posts: n/a
I didn't know they sold those at Best Buy
Old 12-07-2008, 01:31 AM   #5
iamgumby
Fallen Riders
Oh shoot! Not Best But - BIG LOTS, dang it, ssshhhh, I'll edit this and no one will ever know!
Best Buy? Who said anything about Best Buy?
Old 12-07-2008, 06:46 PM   #6
primalmu
primalmu's Avatar
primalmu is on a distinguished road
You know, I just undertook the task of removing the tire off the rear wheel today. The only plans I've seen for bead breakers involved bolting it onto the wall of your workshop (not an option for me) so I ended up buying a 6" C-clamp for under $5 (thank you Harbor Freight!). It was a real bitch breaking the bead because the tires were at least 10 years old and the lube they used to put the tires on had formed a nice glue.
I'll definitely keep this thread in mind if I ever decide to build a bead breaker, though. This is the best design I've seen so far.
2003 Suzuki Bandit 1200 (naked) - SOLD
1984 Honda Gold Wing GL1200 (stripped)
primalmu is offline   Reply With Quote
Old 12-14-2008, 01:43 AM   #7
sollee
Do what u wanna do
sollee's Avatar
sollee is on a distinguished road
Check out YouTube under motorcycle tire change, it shows everything from a pro built device to someone driving his truck on the tire to bust it loose. I choose something in between, similar to the picture but with just two pieces of wood and the shop wall. Works good. Wheel balancer can be built with four skateboard bearings. Ideas at YouTube under motorcycle wheel balance.
sollee is offline   Reply With Quote
Old 12-15-2008, 01:33 AM   #8
iamgumby
Fallen Riders
Yeppers! And if your bearings run free you can put the wheels back on your forks/swingarms and spin balance them right there. That worked on my front...made a balancer for the back.
Old 12-28-2008, 02:31 PM   #9
beatermoto
beatermoto's Avatar
beatermoto is on a distinguished road
Default Kudos
Thats a nice set up!
beatermoto is offline   Reply With Quote
Old 12-31-2008, 06:16 PM   #10
rexmitchell
Administrator
rexmitchell's Avatar
You will have to excuse gumby at his old age he tends to ramble!
Old 02-06-2009, 06:59 PM   #11
MS_Steve
MS_Steve is on a distinguished road
Default Bead breaker
Nice looking basic (get the job done) bead breaker..... it also looks like it'll crack anything from walnuts to watermelons to disagreeable girl friends. And if the Spanish Inquisition ever rears it's ugly head again, you've already got a tool in your arsenal.
Soon as my tread begins to get thin, I think I'll build one for myself.
MississippiSteve
MS_Steve is offline   Reply With Quote
Old 04-04-2009, 02:40 PM   #12
rexmitchell
Administrator
Gumby you should do a how to on putting a tire on the rim....I have seen interesting videos on youtube on how to make a bead on a tire but it always involved lighter fluid....
Old 10-06-2009, 08:49 PM   #13
Fabrakadabra
Newbie
Fabrakadabra is on a distinguished road
That is awesome. I am definitely going to build one, I always get nervous with the bead hammer and my spokes.
Fabrakadabra is offline   Reply With Quote
Old 01-09-2010, 08:56 AM   #14
wera90ex
Road Captain
wera90ex is on a distinguished road
I used to use the ramp door on my trailer to break 'em down. Now I use a shoe I made on the front of my MC lift to pop the bead.
What I haven't seen mentioned is some kind of tire lube. Dawn and H2O in a spray bottle will do it. Makes them easier off and on. Also don't forget to check rotation and balancing dot,align it to the valve stem.
wera90ex is offline   Reply With Quote
Old 01-20-2010, 12:19 AM   #15
vulcanbikeweek
Motorcyclist
vulcanbikeweek is on a distinguished road
i usually just open the valve a little, and pump till some sluid comes out, the close the valve while it is comming out.
vulcanbikeweek is offline   Reply With Quote
Old 01-30-2010, 10:51 PM   #16
Eye Kandi
Eye Kandi's Avatar
Eye Kandi is on a distinguished road
Great Idea, making the best with what you have. Like it!
Eye Kandi is offline   Reply With Quote
Old 01-31-2010, 12:10 AM   #17
gixxer
Newbie
gixxer is on a distinguished road
Wow Very nice
gixxer is offline   Reply With Quote
Old 01-31-2010, 02:29 AM   #18
67fire
Banned
Gumby.
Still helping people today!
Eric
Old 02-02-2010, 01:21 PM   #19
Zim
Newbie
Zim is on a distinguished road
I use 2 12 " c clamps amd 3 12 " pry bars with the wheel on a 25 gallon drum. I drape a cloth over the drum so not to scratch up the rim and and cut 4 3" pices of 3/8 gas hose to go over the bead. I found that the best thing to do is get the tire nice and warm if that is possible and the bead pops right off and the soft tire also helps in the removal and install
Zim is offline   Reply With Quote
Old 03-10-2010, 12:29 AM   #20
Chicago535
Chicago535 is on a distinguished road
we use this tank called the cheetah (for cars), very nice piece to have
Chicago535 is offline   Reply With Quote
Old 03-10-2010, 01:26 AM   #21
AlmostThere
Master At Arms
AlmostThere's Avatar
AlmostThere is on a distinguished road
I've got this neighbor who weighs in around 500 pounds and .....
AlmostThere is offline   Reply With Quote
Old 03-18-2010, 12:38 AM   #22
TixonPB
Newbie
TixonPB is on a distinguished road
Best thing ever! I work in a tire shop and that is definitely the best tool for those pesky goodyear wranglers that never seem to want to seat to the rim.
The rig above is pretty nifty. I just wish our shop's equipment could do motorcycle tires. I wouldn't have to worry about it
TixonPB is offline   Reply With Quote
Old 07-26-2010, 01:34 PM   #23
mobetta
mobetta is on a distinguished road
ok- are the pics gone or is it because i'm a noob around here that i cant see them?....
at any rate, i got my bead broken using a 2x4 for leverage and a trailer.
mobetta is offline   Reply With Quote
Old 07-29-2010, 05:52 PM   #24
LEATHERMAN
LEATHERMAN is on a distinguished road
A wood splitter works good on an atv.
LEATHERMAN is offline   Reply With Quote
Old 04-29-2016, 05:48 PM   #25
springer
springer is on a distinguished road
have used this little system for many years on Harley, Kawasaki and tractor tires to break bead. Just be sure to watch what you are doing and block the tire so you don't damage anything just make sure that the bottle jack is on the tire near the rim. If you try this you are responsible for any damage or issues that may occur. I've had a 100% success rate...
springer is offline   Reply With Quote
Old 04-29-2016, 09:59 PM   #26
Offcenter
On The Road Again!
Offcenter's Avatar
Offcenter is on a distinguished road
Hmm....Looks fine if you have a concrete wall on either side.
I wouldn't try that with the wooden walls in my shop. I might end up pushing the door frame apart.
George in Jersey
CT-90 & Goldwing
Offcenter is offline   Reply With Quote
Thread Tools
