Old 09-29-2008, 11:22 AM   #1
Agon16
Agon16 is on a distinguished road
Default Gas leak
Ok so i just put new jets in my carb and i put everything back together and now gas leaks out of the float bowls. what would be causing this?
Agon16 is offline   Reply With Quote
Old 09-29-2008, 12:04 PM   #2
cbdallas
cbdallas's Avatar
cbdallas will become famous soon enough
Float needles / seats need to be cleaned, or needles need to be replaced and adjusted. Float bowls are filling too full because needles aren't sealing.
cbdallas is offline   Reply With Quote
Old 09-29-2008, 04:54 PM   #3
Agon16
well if i increased the jet size would i have to adjust the float acording to that?
Old 09-29-2008, 06:30 PM   #4
weekendrider
weekendrider is on a distinguished road
You didn't tear the gaskets or forget one?
weekendrider is offline   Reply With Quote
Old 09-29-2008, 07:23 PM   #5
Agon16
the gaskets that follow the outer part of the float bowl?
Old 09-30-2008, 12:01 AM   #6
weekendrider
Yes the gasket that is between the bowls and carb body. Is that where the leak is at, or maybe coming from one of the bolt holes in the bowl?
Old 09-30-2008, 01:14 AM   #7
Agon16
the gaskets are installed and they look in fairly good shape. Maybe my screws just arnt tight enough? i dont know really
Search this Thread:
Advanced Search
