Go Back   Motorcycle Forum > Motorcycle Repair, Building, and Restoration > Building, Restoration & Modification
Building, Restoration & Modification Building a bike, restoring a classic, or making some modifications?
Old 07-30-2008, 05:43 AM   #1
cksurfer
cksurfer is on a distinguished road
Question How do I make my Exhaust Loud?
I heard that I could poke holes in the baffles but it seems pretty shotty....
What have you guys done?
Thanks,
CKSURFER
cksurfer is offline   Reply With Quote
Old 07-30-2008, 07:22 AM   #2
Custom85VT
Guest
Posts: n/a
I took mine OFF.
Old 07-30-2008, 11:15 AM   #3
OldRusty
Who needs a clutch?
OldRusty's Avatar
OldRusty is on a distinguished road
Why do you want to make your exhaust loud? All your gonna do is p-off your neighbors.
OldRusty is offline   Reply With Quote
Old 07-30-2008, 11:23 AM   #4
Custom85VT
Guest
Posts: n/a
^ ...and this is a bad thing? Nope an added bonus!
Old 07-30-2008, 11:28 AM   #5
OldRusty
Who needs a clutch?
OldRusty's Avatar
It is when you have an 11month old trying to sleep.
Old 07-30-2008, 11:55 AM   #6
Custom85VT
Guest
Posts: n/a
^ Yup sure is. The parents of that same child (figuratively not you personally ) didn’t mind when their decision to procreate screamed during for the full duration of my last 12 hour transatlantic flight. Karma goes both ways.
Old 07-30-2008, 01:12 PM   #7
OldRusty
Who needs a clutch?
OldRusty's Avatar
What you describe is not karma.
Old 07-30-2008, 02:39 PM   #8
Custom85VT
Guest
Posts: n/a
I apologies most humbly your presence. I had no idea you were a guru.
In an effort to steer this post back onto cksurfer’s original topic…
Here is an excellent exhaust mod FAQ & guide (w/ pics):
http://www.sa750.com/exhaust/exhaust.htm
Old 07-30-2008, 02:51 PM   #9
OldRusty
Who needs a clutch?
OldRusty's Avatar
Agreed.
I had an eperience with this before. Didn't mean for it to come out here like this though. An old neighbor of mine modded his exhauast to make it louder and not too many people on our street appreciated it at 2 o'clock in the morning.
Old 07-30-2008, 05:55 PM   #10
loudest143
as in "he who laughs last...."
loudest143 is on a distinguished road
Something to consider when changing or altering your exhaust..... You are changing the flow of air through your motor. The intake of air may be affected, and you may need to rejet and rebalance your carbs, which, is THE MOST FUN EVER!
I've heard of people drilling holes into the end of the baffle. I've heard of people removing the end of the exhaust, and taking the baffles out completely, thus making it a straight pipe. I personally took apart a canister muffler and fabricated my own custom baffle that lowered the restriction in the exhaust. Yes, it changed my airflow significantly, and I had to rejet. And that was on a single cylinder bike, so recognize the risks involved, and the time involved in making the bike run properly after your 'mod'.
It's fun, and louder, but it's alot of work also.
loudest143
meh
loudest143 is offline   Reply With Quote
Old 08-03-2008, 03:48 PM   #11
primalmu
2005 Bandit 1200S
primalmu's Avatar
primalmu is on a distinguished road
Also keep in mind that you can actually REDUCE the power of your bike by doing a half-assed exhaust mod. And in the case of drag pipes, even when done correctly, you're still gonna lose a bunch of power unless your running the engine near its redline the whole time (they don't call 'em drag pipes for nuthin!).
Personally, I'd rather not sacrifice HP for dB...
primalmu is offline   Reply With Quote
Old 08-03-2008, 06:08 PM   #12
Custom85VT
Guest
Posts: n/a
Download and read this PDF:
"Understanding Exhaust: The How & Why"
http://www.bigcitythunder.com/pages/...ng_exhaust.pdf
Old 08-04-2008, 01:11 AM   #13
cksurfer
Cool article.
I'm now guessing that poking holes probably isn't the best idea
I've heard of drag pipes (which I believe are straight pipes)...... can you make those things?
Or do car exhaust places form bike exhausts?
Thanks for all of the help
Old 08-04-2008, 01:14 AM   #14
cksurfer
Would my stock pipes and carb settings give me the best mpg?
I've heard that rejetting the carbs and adding new pipes can get you 10mpg. is that a myth?
Old 08-04-2008, 04:59 AM   #15
Custom85VT
Guest
Posts: n/a
Sure, I did. Helps if you have a buddy with a muffles shop (pipe bender).
Old 08-08-2008, 10:53 AM   #16
amanofgreatevil
Chop Builder
amanofgreatevil's Avatar
amanofgreatevil is on a distinguished road
I am might be thinking of cars, but I think it is the same as motorcycle. What about back pressure, and the values in the motor would crack from all the cold air?
amanofgreatevil is offline   Reply With Quote
Old 08-08-2008, 10:57 AM   #17
Custom85VT
Guest
Posts: n/a
Read the link found in post #12
Old 08-08-2008, 11:05 AM   #18
amanofgreatevil
Chop Builder
Right...
Haha, maybe I just showed some info off the link.
Old 08-10-2008, 06:57 PM   #19
baddad0708
Newbie
baddad0708 is on a distinguished road
torq cones solved my back pressure prob. when i pulled my baffles
baddad0708 is offline   Reply With Quote
Search this Thread:
Advanced Search
