Yamaha 1100 V-Star engine noise. - Motorcycle Forum
Go Back   Motorcycle Forum > Manufacturers > Yamaha
Notices
Thread Tools
Old 07-19-2008, 01:32 PM   #1
Royal
Royal's Avatar
Royal is on a distinguished road
Default Yamaha 1100 V-Star engine noise.
My brother has an 05 1100 V-Star which he says has a clicking sound in the engine. He tells me it sounds like a valve tappet click only somewhat louder. He has pulled the engine and replaced everything he thinks could be causing it but it is still there. The dealer he bought it from claims it sounds completely normal so he was no help. (I know the dealership, it changed ownership since he bought the bike and personally I wouldn't trust them any farther than I could throw the bike). I thought I read a post about the same thing some time ago but I can't find it. Have any of you 1100 V-Star riders had anything that sounds like what I have described or is this really normal? I haven't gotten to listen to the noise but my brother is really savy on what something should or shouldn't sound like.
Any suggestions?
Royal is offline   Reply With Quote
Old 07-19-2008, 03:47 PM   #2
Cruzrat
no title needed
Cruzrat's Avatar
Cruzrat is on a distinguished road
The 1100 does make a tapping sound normally, but it could need a valve adjustment too, that would not be anything out of the ordinary.
Hard to say with out hearing it
I'd take it somewhere else for a second opinion, of check the valves yourself.
http://www.vstar1100.com/vs1100valves.pdf
Rat
Cruzrat is offline   Reply With Quote
Old 07-22-2008, 08:37 PM   #3
rickh03301
Motorcyclist
rickh03301 is on a distinguished road
I got an '06 1100.Got about 2300 mi. on it.I wanted to get the 600 mile service done on it when I was away and the local shop couln't fit it in the schedule.They did do a oil/filter change on it and told me that it didn't seem to need any other adjustments so I should be fine.Then I started noticing a clicking sound while driving the bike.I thought maybe it was there all along and never noticed it before but it was driving me crazy.I asked my buddy to take a listen and he thinks it is normal for this machine to make this noise.He also said that maybe it might be in need of a valve adjustment.
Now I am making an appointment to have it serviced.I am a bit nervous because I should of had it done at 600 miles or as soon as possibe afterwards.I can only hope there is nothing damaged as I'll have some explaining to do to my warrenty.Hope everyone telling me there is nothing to worry about knows what they're talking about.
To all the NEW riders out there just getting started may I suggest:Read your warranty agreement and don't prograstinate.Have it serviced on schedule and have it looked at if something ain't right.
Rick
rickh03301 is offline   Reply With Quote
Old 07-23-2008, 01:17 PM   #4
denofearth21
Master At Arms
denofearth21 is on a distinguished road
I have an 07 1100 and i noticed the ticking on it as well. I now have 8000 miles on it and had it serviced earlier then recommended. The dealership and others that i know said that theres a slight tick in most of the v stars.
denofearth21 is offline   Reply With Quote
Old 07-26-2008, 11:01 PM   #5
suzyq
Motorcyclist
suzyq is on a distinguished road
Hi I have the v star 1100 2008 and my husband has the 2004 they both make a fast ticking sound.
suzyq is offline   Reply With Quote
Old 09-07-2008, 07:42 PM   #6
DarkHorse9825
DarkHorse9825's Avatar
DarkHorse9825 is on a distinguished road
I just bought a 2003 V-Star 1100 with 6800 kilometers on it (not sure what that is in miles?) Anyway, I did notice a ticking too. This is my first road bike and thought it was possibly the gas, so I filled it with medium grade (89). There is still ticking. From what I have read so far this seems to be the norm.
Can anyone tell me if I am wasting money on the higher-octane fuel
DarkHorse9825 is offline   Reply With Quote
Old 09-08-2008, 05:17 AM   #7
rickh03301
Motorcyclist
I wouldn't say you're waisting your money,but unless your owners manual specifically states to use high octaine gas you shouldn't need to.My '06 only needs unleaded gas as per my manual.That said I switch type of octain depending what I can afford at the time.I try to at least use 89 octain gas.In the long run it keeps the carb cleaner,plus you will see a little better gas milage as well.
Rick
Old 09-08-2008, 08:45 AM   #8
Cruzrat
no title needed
Cruzrat's Avatar
I tried all types of octane gas in my 1100 and never could tell enough difference to matter. The only real difference was gas that had ethanol got less mileage than without ethanol.
I'd save your penny's and use the regular stuff ..... but then at maybe .10 cents per gallon diff..... .40 cents per tank wont kill ya either
Rat
Old 09-17-2008, 10:09 AM   #9
meadows
meadows is on a distinguished road
The valves need adjusting. They are supposed to be adjusted at the initial 600 mile service and them every 4000 miles.
meadows is offline   Reply With Quote
Old 09-17-2008, 06:55 PM   #10
Cruzrat
no title needed
Cruzrat's Avatar
According to the manual maybe..... but I put 42k on mine an never needed a valve adjustment ( had 'm checked) It always made a ticking noise too.
each bike is different, some may need adjustments more than others
Rat
Old 09-18-2008, 06:25 PM   #11
02cutominfl
Master At Arms
02cutominfl is on a distinguished road
I found on mine atleast, that when I adjusted the valves to the tightest recommended valve lash, combined with synthetic oil, no longer ticks.
02cutominfl is offline   Reply With Quote
Old 04-01-2009, 09:19 PM   #12
wolfrages
Motorcyclist
wolfrages is on a distinguished road
i got two problems with my bike, one it's started to burn alot more oil then normal...am going though 2bottles in less then 3 months of riding...2000klm, yea i ride alot
neways i filled it up just the other day and now it's ticking, never used to...checked the oil and everything...figured i should change the oil or somin, got all setup to change the oil and ended up fighting with getting the oil plug off, witch way dose it turn on a 98 v-star 650 and can you get a socket in their?
also is it possible to have a old oil buildup on the engine block? last time i changed the oil it, when i put the new oil in it turned black in one ride....is the normal?, i'v only had this bike since sept of 08
wolfrages is offline   Reply With Quote
Old 04-02-2009, 12:13 AM   #13
wking72650
wking72650 is on a distinguished road
The time to worry about a vstar 1100 engine is when it stops ticking.
wking72650 is offline   Reply With Quote
Old 04-02-2009, 09:43 AM   #14
Badlands-4-2
Super Moderator
Badlands-4-2's Avatar
My 1100 ticks also. I have done, and redone the valves. I have been told by the dealer that Vstars tick like that, always.
Old 04-02-2009, 09:01 PM   #15
skooter Bum
skooter Bum is on a distinguished road
I have an 2008 V1100 Custom and it has 1265 miles on. And it has a ticking noise. Not loud but you can hear it. It's not noticeable at speed so I don't worry about it. As long as the engine light doesn't come on and the sound doesn't get louder,....I'm not going to worry about it. The ticking noise is one of those idiosyncrasy of a V1100.
As far as using 89 or 91 octane gas,......well the V1100 compression ratio is only 8.3 to 1. So I would stay with using the 87 octane. You might, just might see a little improvement in performance using 89 octane gas, but unless you change the exhaust, rejet the carbs and open the air box,....you really won't see any real performance increase.
skooter Bum is offline   Reply With Quote
Old 04-03-2009, 01:14 PM   #16
internationalballer
internationalballer's Avatar
internationalballer is on a distinguished road
I agree with every one else, V-star 1100's click, its normal, I have never heard anyone say different and since everyones v-star does it I'm sure I would have heard by now. Best way to fix the clicking sound is take off the weak pipes yamaha put on the v-stars and get some that are loud.
internationalballer is offline   Reply With Quote
Old 04-03-2009, 01:35 PM   #17
DarkHorse9825
Ah, drown out the clicking sound with loud pipes. I like your way of thinking internationalballer
Anyway, Custom pipes are better for performance.
Old 04-03-2009, 02:11 PM   #18
Schneiderman
Schneiderman's Avatar
Schneiderman will become famous soon enough
If the noise is from the valves, "tappy valves are happy valves" and you should only worry when the tick goes away. But, it could be an exhaust leak. My dad's vstar had an exhaust leak and it sounded similar to valve noise.
Big Government is a problem, not a solution.
Schneiderman is offline   Reply With Quote
Old 04-04-2009, 09:58 AM   #19
ScottsCustomCycles
ScottsCustomCycles is on a distinguished road
Just want to back up what everyone else is saying. Do Not tighten those valve clearances to the point they stop ticking. V-stars should tick.
I have two of these bikes: one with over 35,000 miles and 1 with only 22, 000 miles. Both bikes have had their valve clearances checked by me every 4000 miles, and only the higher mileage bike has ever needed adjusted and that was at the last 32,000 mile check.
For you guys who are tight on funds and don't do you're own work, I would have these things checked no more often than every 16,000 miles after the initial 600 mile check unless you really notice power drop in the bike.
I'm sure a Yamaha mechanic will dispute this but that's my experience.
ScottsCustomCycles is offline   Reply With Quote
Old 04-23-2009, 11:33 PM   #20
wking72650
I agree, my 07 1100 dont tick since i put the vance and hines cruzers on.
Old 04-05-2010, 03:35 PM   #21
boats
boats is on a distinguished road
i just adjusted my valves wich i found were tighter than specs, tickin noise is still there, seems like its comming from the starter?
boats is offline   Reply With Quote
Old 04-10-2010, 04:19 AM   #22
johnnnyo
Master At Arms
johnnnyo's Avatar
johnnnyo is on a distinguished road
My 2002 V-Star classic ticks as well. Totally normal. Put some loud pipes on and you will only hear it when your sitting still. The key is to not sit still.
johnnnyo is offline   Reply With Quote
Old 04-10-2010, 07:08 AM   #23
4Raven
Super Moderator
4Raven's Avatar
4Raven has a spectacular aura about
Okay, how many of the Vstar owners also have exhaust blueing occuring also with the ticking....here is another little note from another website I found...on blueing...
Most any pipe can and will. And there is only one culprit…EXCESSIVE HEAT!! If your bike is mis-timed….too much heat. Run lean? More heat. Run out of gas? (more air than gas)…heat again! In these instances, more air than fuel will result. And with the induction of more air, temperatures can flair as much as 200 degrees instantly; thus frying the pipes.
...Now I just took mine in for a valve adjustment....but not a timing...check...but I am going to ask about that also....because I have noticed that I am getting a blueing effect....is there a chance that the two are related? Ticking and mis-timed?
The woman who follows the crowd will usually go no further than the crowd. The woman who walks alone is liable to go to places no one has ever been before. - Albert Einstein
4Raven is offline   Reply With Quote
Old 04-10-2010, 08:03 AM   #24
wking72650
I have allways heard that if your pipes turn a blue color you are running rich and if they turn a yellow/gold color you are running lean, this can allso be checked by looking at the spark plugs.
Old 04-11-2010, 08:45 PM   #25
4Raven
Super Moderator
4Raven's Avatar
took the bike in and they adjusted the valves and sync the carbs...no more ticking...
said my blueing is most likely letting the choke on too long...but I thought I saw where you were supposed to let it warm up for five minutes...so am I causing the blueing by letting it warm up then?
Old 04-14-2010, 06:48 PM   #26
valkyrie
Motorcyclist
valkyrie is on a distinguished road
I have a 2003 Valkyrie that makes a clicking sound that to me sounds the same when you pull a plug wire off and the spark arcs. It does not make the sound when it first warms up, only when its hot. It seems to go away at higher RPMs but I think that because the engine covers the sound. Any thoughts?
valkyrie is offline   Reply With Quote
Old 04-15-2010, 03:25 PM   #27
johnnnyo
Master At Arms
johnnnyo's Avatar
Mind if I ask what you paid for the valve adjustment and carb sync?
Old 04-16-2010, 06:13 AM   #28
4Raven
Super Moderator
4Raven's Avatar
Paid $225 forhttp://www.motorcycleforum.com/showthread.php?t=100506
Already had a thread for it......
At first I balked at the cost...but really they did a lot of stuff...I am still having to get used to the clutch again...need to have that readjusted again!
But I think they did a lot for the money!
Old 04-16-2010, 03:19 PM   #29
johnnnyo
Master At Arms
johnnnyo's Avatar
Thanks 4Raven. I was curious because I know some ticking is normal but I think mine is getting abnormal. I'm considering bringing in my 1100 to get checked out.
Old 04-16-2010, 04:34 PM   #30
4Raven
Super Moderator
4Raven's Avatar
There seems to be a little bit there, but mine has really reduced what I heard before...I am thinking...I am going to get the necessary tools to do that myself....because i don't want to have to do it every 2,000 miles....jeeze that would be after every trip I take or better!
Old 04-16-2010, 09:42 PM   #31
rustydog
I fear no beer
rustydog is on a distinguished road
The valve adjustment is something I started doing myself last year cause I was tired of forking out 300 bucks every time.
rustydog is offline   Reply With Quote
Old 04-17-2010, 07:00 AM   #32
johnnnyo
Master At Arms
johnnnyo's Avatar
Step by step instructions for a valve job
Old 04-17-2010, 08:53 AM   #33
4Raven
Super Moderator
4Raven's Avatar
Do you have one for a 650?
Old 04-17-2010, 09:21 AM   #34
johnnnyo
Master At Arms
johnnnyo's Avatar
Here ya go.
http://www.650ccnd.com/valve.htm
Old 04-17-2010, 09:41 AM   #35
4Raven
Super Moderator
4Raven's Avatar
Too cool thanks.....
Old 07-28-2010, 05:05 AM   #36
Charley Horse
Charley Horse's Avatar
Charley Horse is on a distinguished road
Default 2009 YAMAHA 1100 issues...
Too often as I approach intersection to stop, engine will make sharp "clack" sound and stall... however it starts right back up after wards.
Bike has nearly 5k miles... dealer did 600 mile oil change/check up... problem didn't start until after 2nd oil change @ 4k miles.
After reading several threads, I'm speculating the bike many need a valve adjustment... is this a service that would be covered by warranty given I purchased bike less than 12 months ago? Is this problem common w/1100 V stars?
Comments/suggestions?
Charley Horse is offline   Reply With Quote
Old 07-28-2010, 07:27 AM   #37
4Raven
Super Moderator
4Raven's Avatar
I have noticed less noise when I change the oil ...going to change the oil more frequently!
Old 07-28-2010, 01:44 PM   #38
Charley Horse
... this "clacking" didn't start until after my second oil change, since then, it's been getting more frequent as now once the bike warms up, it typically happens every 3rd/4th time I come to a stop.
I called the dealer and he said to bring it in for check-up as my warranty runs out in 30 days... although I was thinking valve adjustment, dealer said that "clacking" is how the engine sounds when it stalls... dealer said it could be idle is low (FWIW... I had already adjusted idle slightly higher...); now it's starting to back fire @ low RPMs... I've run multiple tanks of new gas through it from different stations so I doubt it's the gas.
Guess I'll see what the dealer says and hope for the best; the reason I bought a new bike is I didn't want to deal w/mechanical issues... not enough time in my schedule to ride let alone work on a bike when I'm off work.
Thread Tools
