Thread Tools
Old 04-15-2008, 04:35 PM   #1
iamjustifyd
iamjustifyd's Avatar
iamjustifyd is on a distinguished road
Default Wanting a little louder
Heya folks,
I would like to get the bike to be a little louder when I'm riding. 1980 cm400..any way to do this without buying new exhaust? I'm not that mechanically inclined and not wanting to put a lot of money into it.
Thanks
iamjustifyd is offline   Reply With Quote
Old 04-15-2008, 05:00 PM   #2
coons213
Guest
Posts: n/a
I've seen this most commonly accomplished by drilling out the baffles of the stock pipes. The baffles can be removed completely or you can simply drill holes in the back of them. I would not advize removing the baffles completely, at least not at first. If you just drill some holes in the back it should give you a little more sound without affecting performance much. If the holes are too big or the baffles are removed the bike might not run right. You can always enlarge the holes as you see fit, but be careful unless you want to rejet the carbs or something like that.
Old 04-15-2008, 06:36 PM   #3
stein75
stein75's Avatar
stein75 is on a distinguished road
coons213 is right about the carb rejet.
if you take the baffles out completely you may also have problems getting an inspection sticker.
my current situation, the previous owner took them out of my bike and i can't get a sticker.
stein75 is offline   Reply With Quote
Old 04-15-2008, 06:44 PM   #4
iamjustifyd
If I drill holes I'm guessing they should not be big holes? and not a lot of them. and should I do in both to keep things balanced? thanks
Old 04-15-2008, 08:47 PM   #5
CW_SQUARE@comcast.net
Motorcyclist
CW_SQUARE@comcast.net's Avatar
CW_SQUARE@comcast.net is on a distinguished road
why dont you try going to your local cycle shop and check out if the have some lightly used pipes they are willing to unload.
CW_SQUARE@comcast.net is offline   Reply With Quote
Old 04-15-2008, 09:02 PM   #6
jag1
Guest
Posts: n/a
Thumbs up
I just drilled my pipes on my suzuki vl800
4 holes each 1/2" each. a little louder, and I love it.
I say go for it. but it's your call.
I used a step bit, down to 1/2". 8 holes took 5 min.
Old 04-15-2008, 11:05 PM   #7
coons213
Guest
Posts: n/a
Great idea.
Also, 1/2 inch seems to be a good size. I have three holes in each, but my bike is a little smaller.
Old 04-16-2008, 01:35 PM   #8
Custom85VT
Guest
Posts: n/a
I distinctly remember a warning stamped on the outside of my muffler assembly (back when I had them on the bike LOL) that stated something along the lines of "tampering is a violation of federal law"!
So don't make me turn all of you in to the Mattress Tag Police! </joke>
Read:
http://www.aimag.com/epa/Jan06-pt1.htm
Old 04-16-2008, 08:48 PM   #9
cecilbdml
cecilbdml is on a distinguished road
Don't bend over when you drop the soap!
cecilbdml is offline   Reply With Quote
Old 08-31-2008, 11:41 AM   #10
Pamm R
Pamm R's Avatar
Pamm R is on a distinguished road
I put 7 7/16 holes in my suzuki 1800 and it sounds better than stock. It did not change the way iy runs. Just now I can hear when I want to shift. I started with an 1/4 inch hole then went to 7/16 . First i did 3 holes and it sounded to much like a tin can sound. so after 7 it went back to a deep sound in my bike, yours may be different
Pamm R is offline   Reply With Quote
Old 10-12-2009, 12:03 AM   #11
Animedevildog
Zombie? RUN IT OVER!!!
Animedevildog's Avatar
Animedevildog is on a distinguished road
I think I am going to try the holes thing on my exhaust this week. The exhaust note on my ACE is non-existant at an idle it seems, and I would like to get more bark from it. (hey, as they say, Loud Pipes Save Lives) Unfortunatly, money is an issue for me, so buying a new exhaust is at the moment out of the question.
Animedevildog is offline   Reply With Quote
Old 10-13-2009, 07:32 PM   #12
lpmasamune
lpmasamune is on a distinguished road
mount a few megaphones. that should be fun.
lpmasamune is offline   Reply With Quote
Old 10-13-2009, 09:57 PM   #13
Animedevildog
I did that trick with the drill, and it worked well for me. My bike is somewhat louder with a bit of a bark to it now. also, it seems to have freed up a few ponies for me. Not a whole lot, mind you, but enough to notice.
Old 12-03-2009, 12:38 AM   #14
shadyrider
shadyrider is on a distinguished road
Hey i just got my first bike a couple months ago. Its a 04 shadow 600 and have been thinking about doing the same. Are you guys drilling the bottom of the exhaust. I am a complete noob so bare with me.
shadyrider is offline   Reply With Quote
Old 12-03-2009, 12:40 AM   #15
Animedevildog
Not the bottom, but the back plate of the muffler.
Old 12-03-2009, 11:43 AM   #16
subhuman
subhuman's Avatar
subhuman is on a distinguished road
Did you have to rejet devildog? I've been considering doing this as well, but I've never had to rejet my carburetors and don't know how.
Semper Fi
subhuman is offline   Reply With Quote
Old 12-03-2009, 05:40 PM   #17
Animedevildog
hey fellow Leatherneck, just so you know, for that, I do not have to rejet. If I move the e-clip on the needles down one notch, that should bring it right back to where it needs to be.
What is it you ride subhuman?
Old 12-03-2009, 08:37 PM   #18
subhuman
subhuman's Avatar
Its an 85 Shadow VT700C. Thanks for the help, I'm going to go for it, my carbs are in need of a rejet anyhow. Hopefully I can find something around here that'll help me out with that.
Semper Fi
Old 12-04-2009, 04:06 PM   #19
Animedevildog
Well, I'd say if you could get to my place, I might be able to help you with that, but it's gonna be tricky riding across the water! (maybe if you build up enough speed, you can hydroplane across? jk)
Old 12-04-2009, 06:12 PM   #20
subhuman
subhuman's Avatar
I'll see you Sunday
Semper Fi
Old 12-04-2009, 06:15 PM   #21
Animedevildog
LMAO!!!
Old 12-04-2009, 06:22 PM   #22
DennisTheMenace
Motorcyclist
DennisTheMenace is on a distinguished road
I got the jugs bub huggers on my honda vtx 1300 c its a nice sound, not too loud but not quite. you can crack it well
DennisTheMenace is offline   Reply With Quote
Old 12-22-2009, 04:30 PM   #23
bbrooks903
Motorcyclist
bbrooks903 is on a distinguished road
how did that work out for you i have an ace and was debating on doin it?
bbrooks903 is offline   Reply With Quote
Old 12-23-2009, 11:05 AM   #24
gr8fuljohn
gr8fuljohn's Avatar
gr8fuljohn is on a distinguished road
I just drilled out my baffles and it made my bike sound real nice
gr8fuljohn is offline   Reply With Quote
Old 12-24-2009, 02:33 PM   #25
Animedevildog
Great to see a fellow ACE rider!
It worked nicely for me. I do have a spot in the powerband that is running a bit lean (guess I won't be riding up Mt. Washington) but overall, I did notice an increase of power (due to slightly less exhaust restriction) and a little more sound out of the bike.
I still want more though. I intend on making a custom muffler for the ACE that will give considerable more of an angry growl and virtually zero exhaust restriction. I have done some looking, and I can make this for about the same cost as buying an aftermarket exhaust, but will give the look that I want. To match this, I will have to greatly open up the air cleaner housing and install a Stage III jet kit into it. In the end, I should have a marked increase of power.
Old 12-27-2009, 02:33 PM   #26
Tattoo Paul
Motorcyclist
Tattoo Paul is on a distinguished road
I don't know how things are down your way, but here in the New England area there are a lot of towns that are cracking down on modified / loud exhausts. Nice juicy tickets to help close the budget deficits.
Tattoo Paul is offline   Reply With Quote
Old 12-27-2009, 07:18 PM   #27
Animedevildog
Yeah, I know about all that Paul. Here in Maine, the City of Portland was cracking down the hardest, and UBM stepped up to the plate. Thay've toned it down a bit on the crackdown. There are a few other communities in Southern Maine doin that as well, and up here in the Waterville area, we have one Statie who seems to be on a personal vendetta against any and all loud bikes. Officer MacGuyer. I call him Lizzie.
Old 12-30-2009, 03:43 PM   #28
subhuman
subhuman's Avatar
I drilled mine out too, I put about five 1/4" holes in each pipe. It sounds great and my bike was running rich so it kind of evened out now. I can feel a slight increase in power as well. I'm glad I did it.
Semper Fi
Old 01-18-2010, 07:29 AM   #29
Mr_CRF
Newbie
Mr_CRF is on a distinguished road
just remember that you will probally have to rejet after drilling the baffels
Mr_CRF is offline   Reply With Quote
Thread Tools
Copyright © 2006 - 2009 Motorcycle Forum | About Motorcycle Forum | Advertising Opportunities | Legal | A member of the Crowdgather Forum Community
