Old 11-01-2007, 06:22 PM   #1
boyer242
boyer242 is on a distinguished road
Exclamation 1983 Nighthawk won't turn on
I'm wondering if I can get any suggestions on why my nighthawk won't even turn on. I know that the battery is charged right now and it still won't work. A couple weeks ago it showed some signs of life when I turned the key on, but bit by bit when I tried to start the bike it died. Now not even the headlight or the controls react when I turn the key. Any advice would be great! Thanks.
boyer242 is offline   Reply With Quote
Old 11-17-2007, 05:09 PM   #2
KLN
KLN is on a distinguished road
silly question but important....is there gas in the tank???? Other than that not sure. been told it could be a bad starter or carbs that need cleaning.
KLN is offline   Reply With Quote
Old 11-18-2007, 12:53 AM   #3
slicknick218
slicknick218's Avatar
slicknick218 is on a distinguished road
It wouldn't be out of the question for the ignition switch to be going bad. I do know that the nighthawk will still fire with the fuel tank off because I have an 83 nighthawk 550 project in the garage right now. I can't say for certain on the honda but it does hold true for suzuki of the same era that if the headlight switch is broken or not making proper contact through it connections you can get a LOT of really wierd, seemingly unrelated issues.
slicknick218 is offline   Reply With Quote
Old 11-24-2007, 05:36 PM   #4
cecilbdml
cecilbdml is on a distinguished road
Either your ignition switch or your main power module (just after the battery) are failing. Neither one is particularly cheap to replace; neither one is particularly DIFFICULT to replace.
Considering the fact you have one of Honda's best, the expense, IMO, is worth it.
cecilbdml is offline   Reply With Quote
Old 11-24-2007, 05:58 PM   #5
CB750F
Shantytown Mayor
CB750F's Avatar
CB750F is on a distinguished road
Check the battery cables first. Sometimes a dirty or corroded one will do that. Sometimes they get corroded at the terminals where they met the plastic and you can't see that they are broken.
07 Ninja 500
98 ZX6E
CB750F is offline   Reply With Quote
Search this Thread:
Advanced Search
